building 455 e-heads for street strip any opinions on rods will be using trw pistons thanks
Butler perfromance has a good set of 5140 steel rods for under 300 bucks, any cheaper and the`ll come for free in a box of cracker jacks!
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears 66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
^this is all you need.
Good luck finding Carillo or Oliver rods UNDER $1,500 per set. Crower Sportsman rods are nearly $1,000 per set.
It takes considerable knowledge just to realize the extent of your own ignorance. Dr. Thomas Sowell |
Agreed. Carillo or Oliver are indeed nice rods, just not needed here. A ton of motors out there making big numbers on Eagle rods and living just fine. My 455 with iron heads turns 5800 out the big end in the 1/4 with TRW pistons and get this, "CAT" I beam rods. No problems to date. I would feel fine running either Eagle or Tomahawk 4130 rods. Both rods will be running fine when the block splits in half.
![]() Quote:
Dave "Big Injun" Anderson dave@4mypontiac.com www.4mypontiac.com For GTO Celebration items click the tile coaster. ![]() |
I've used Tomahawk 5140, 4130, 4340 forged rods for more than 6 years in numerous builds- they are good rods and reasonably priced. If you want Oliver or Crower rods you'll have to pay for them- good quality rods but overkill for a street engine IMO. The Tomahawk rods have been on the market for over 10 years now, and are proven performers at this point. PPR sold them for over a decade and we all know Ace Brewer would never sell junk.
For a 500 hp build with e-heads I would step up to either a 4130 or 4340 I-beam. I used Tomahawk 4340 A-beams in my 455 SD Performance e-head build- they're the lightest forged steel Pontiac rod on the market (690-710g), and rated to over 800 hp. Tim Corcoran sells the Tomahawk rods now- give him a call and he'll set you up. Geno |
i got some great scat bushed H beam rods for my 455 from Amazon. seller was scat. shipped from Amazon in 2 days for $525. even my engine builder was surprised and could not get them for less at his cost.
Jim |
thanks for the advice ordered a set from TIM at Tomahawk .
