Old 11-19-2023, 12:14 AM
chiefbigb chiefbigb is offline
Default 1956 Pontiac dual quad engine information needed
I'm asking for information on this engine for a friend of mine. He has found what he believes to be a old nascar engine and is hoping to get some more information to decode it. All I know at this point is it's a 56 dual quad engine.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
Old 11-19-2023, 12:30 AM
Sirrotica's Avatar
Here's a link with some info on that engine:
https://pontiacsafari.com/L1EarlyV8P...uad/index.html
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 11-19-2023, 12:54 AM
tom s tom s is offline
Rick Gonser is a tech advisor for POCI.You should be able to get his number from the Smoke Signal monthly mag.tom
The Following User Says Thank You to tom s For This Useful Post:
Old 11-19-2023, 07:30 AM
steve25 steve25 is offline
Just the air cleaner assembly for that motor is worth a small fortune if it’s still present.!
Old 11-19-2023, 08:11 AM
Thank you. I will attempt to contact Rick. Will post pics if he sends any
Old 11-19-2023, 08:12 AM
sdbob sdbob is offline
I saw one when I was very young. Wow! I thought. I think that is where that 524886 camshaft originated.
Old 11-19-2023, 09:02 AM
Half-Inch Stud's Avatar
Hmmmm, wonder if the 1956 Salt Falts Pontiac Engrg 24 hour lifetest video (about 15-20minutes) is the Ab Jenkins 24 hour run.
Is on CD, and willing to know best way, place to upload it.
Old 11-19-2023, 12:06 PM
Few pics
ID:	623470   Click image for larger version
ID:	623471   Click image for larger version
ID:	623472   Click image for larger version
ID:	623473   Click image for larger version
Old 11-19-2023, 12:08 PM
Heads are not the original 2 4 castings from what I can tell.
Old 11-19-2023, 12:54 PM
Block number looks correct
ID:	623477   Click image for larger version
Old 11-19-2023, 03:01 PM
Those are the correct head casting numbers according to the info I have.
Old 11-19-2023, 04:07 PM
Wallace racing showed 522845 as the 2 4 heads. From what little I know the ones he has have a bigger combustion chamber and need cut .071 to get the same compression ratio. Other than that both heads are the same
Old 11-19-2023, 06:22 PM
Thanks for sharing. Looks like some hd cast iron around the mains.
Old 11-19-2023, 10:06 PM
BILL BOWMAN1's Avatar
Looks quite solid in the lifter bore area!
Old 11-20-2023, 07:50 AM
Cam should be 522869,sorry. Other nos. Block#, manual trans 'S', auto 'H'. Head cast for all 56 V 8 522010. I do not have specific chamber volumes. From my listings intake,#523554. Distributor # 1110875. Carb # 7009820. Good luck. Nice find.
Old 11-20-2023, 10:00 AM
2-blot block was good enough for early nascar huh. Wonder what rods were successful.
Old 11-20-2023, 10:11 AM
Here's screenshots from Craftsman Service News on the 285 HP engine:
ID:	623508   Click image for larger version
ID:	623509   Click image for larger version
Old 11-20-2023, 06:54 PM
Thanks John and everyone else for the information. Very helpful
Old 11-21-2023, 01:41 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Interesting specs John. Ignition timing surely wasn't "aggressive"- no more than 30 degrees @ 4,000 RPM!
