Common oversize. .030, .040, and .060 are the most common oversizes and are pretty much available from ANY engine parts supplier.
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
When you mill heads do you need new shorter push rods? |
What these two guys said, plus put big valves in those heads and have the machine shop use a throat cutter to add a 1.66" or so backcut under the intake valves. Also convert to screw-in studs.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
A good rule of Thumb for a street motor with a decent flowing iron head is that Lift wise at the valve you will need.110" lift for every 100 hp your loooking for the motor to make.
All stock 1968 and up small valve Pontiac heads with 30 degree Intake seats flow 180 cfm @ .500" lift. If you look at post 19 in this string where the motor developed 360 HP that level of power took 174 Intake cfm per cylinder to make that 45 HP per cylinder. Big valve iron heads will generally already be flowing 200 cfm @ .450" lift, so you can see why it will always pay to step up to bigger valves with the needed valve job if you need new valves anyway, and all iron head needs new valves if they have over 45,000 miles on them so don't kid yourself!
Most that I have come across have 30s, but yes a bunch 45 seats.
I think that more casting numbers where made with 45 degree seats before 1971, but production numbers used of heads with 45 degree seats was higher after 71.
yes, if you shave the heads enough that will change the geometry & may require new push rods, but those are pretty cheap, or you may still be ok if you dont mill too much... back in the 90's on my first 455 before i knew much about checking push rod lenghts, with .040-.050 shaved 6x heads the rockers still sat pretty close to centered on the valve tip & had no issues with lots of miles & abuse. i said most of that before they did... |
Please note that the smaller the total combustion chamber volume then the higher the vacuum level will be for any given Cam used.
I.e, a 400 motor with a 068 Cam and 9.5 comp will pull more vacuum then the same motor with 8.5 comp. |
Footjoy, running #16 heads (75 cc's stock chamber) will push your compression to 10.2 to 1, especially if they need a clean-up cut. You still want to run a .027" Cometic head gasket to keep quench as tight as possible, but the distributor timing curve will need to be tailored to stay out of detonation. Dennis |
Get some KRE heads and a cam matched to the combo.
************************************* 1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude |
It's all so easy to just open up someone else's wallet isn't it?
My math isn't working bore 4.16 stroke 3.75 heads 75CC gasket .045 Deck height .021 I come up with 9.65 SCR Where am I going wrong and I know that head gasket is big. Is there a camshaft that would maybe help to bring it down to 9.5? Thanks |
using those numbers & 6.6cc piston valve relief & 4.3 gasket bore size, i get 9.61. so i think you're pretty close. & 9.5 is an excellent compression for a pump gas engine, should be able to select a good cam for that compression & make some decent power. http://www.wallaceracing.com/cr_test2.php |
Dennis |
Use a Butler head gasket,46 thou compressed.Your close enough that even I would not worry about it.Tom
comparing a .027 gasket to a .046 head gasket what will I lose by doing that? Thanks Greg |
Yes, it effects HP by means of a faster burning of the air and fuel mixture with less needed timing and as a side benefit it allows for better fuel efficiency .
There's nothing fully cut in stone in regards to what the quench clearance should be as the amount of square inches of quench clearance formed by the top of the piston and the chamber shape varies with the shape of each of these. In short if your piston deck clearance is zero and the head gasket you are running compresses to .045" your as golden as golden gets with a street / strip motor. Also in this same vein running a deck clearance of .025" and a compressed head gasket of .027" does not provide the same mixture agitation as the above example even though there quite close number wise!
#38
In my case I am .021 deck clearance and want to use a .046 head gasket to achieve 9.6 compression.
What will I lose with this combination.? I guess that is a open question. Thanks Greg |
#39
I'm not certain I'd go in that direction. Although you may slightly drop the compression ratio of the engine, what little bit you gain there is offset by worsening the quench distance. You may actually be more prone to detonation than you are currently.
Do you have verifiable measurements that your pistons are .021 in the hole or are you providing that information based on a piston spec sheet? Depending on the actual deck measurement of the engine, after any remediation for twist, warp and surface finish, it's possible your pistons aren't actually that far down. If you have a set of the common TRW/SPeedPro pistons in your 400, the listed compression height of the piston is 1.714, so you can calculate rotating assembly height by 1/2 the stroke + rod length + piston compression height. Such a rotating assembly would give a deck height of 10.214" Accounting for even just a minimal surface on the head mounting surface of the block, you'd be looking at a deck height of more like around .007-.005 in the hole.
#40
