Whats a "respectable" M.P.G. for this car?
What do you guys think is a respectable M.P.G.
for a 455? Any improvements I can make? I recently took a vacation day and put a few miles on my T/A I decided to keep track of the Fuel used & miles driven. The car is a mostly stock 1975 Trans Am with a 455, 4 speed, 3:23 rear, no A/C, 068 RA/4 H.O. cam, MSD Ignition, hedders & 2.5" flowmasters re worked 72' 455 HO quadrajet, stock 6H heads. Over 318 miles driven thru Philadelphia to the New Jersey shore 75% Highway at about 55 to 65 MPH and 25% stuck in Toll Booth & Philly traffic "stop & go" I averaged the MPG and got 16.5 MPG Is this pretty good or pretty bad for what I have? range between fuel stops was about 90-100 miles to get there & home. I used mostly 89 octaine, it does not seem to care what it runs on with the big chamber 6H heads so I went with the "cheaper" gas I really tried to go easy on it and pulled about 20-24 inches of Vac. at a cruse speed, and about 2,500-3,000 at 60 MPH I learned alot about saving some fuel with the vac gauge, 3rd gear at a slightly higher RPM pulls more Vac than 4th gear at a lower rpm, the 455 has so much torque & pull its sometime hard for me to judge when to down shift. I always assumed the Higher RPM is what used fuel faster, Using the gauge works great so I'm glad I installed it. I also learned its VERY hard NOT to put the pedal to the floor when doing a long range M.P.G. test on a car with a 455 LOL!
Jason Rackawack 1975 455 Trans Am - 1975 Firebird 400 Last edited by Rack776; 05-27-2009 at 03:33 PM. |
My 77 GP use to be set up pretty close. It got 13-17 so I would say your in the ballpark.
My TA gets 17 highway (70-75mph) and 14.5 around town. It's far from stock. Dynoed at 420hp and 520 torque.
Heck, my 70 Bonne w/360 horse 455 in it gets 18 and 13, and it's bone sock. I wouldn't worry to much about it.
70 Bonneville 455, survivor (Third Owner) |
I would say you are doing quite well for that combination!
Admiration for Ponchos.......... |
you're doing fine, i run on the smiles per mile meter. if i were to think in terms MPG, with mine in the single digits i'd never enjoy driving it!
