Old 02-17-2022, 04:39 PM
jhein's Avatar
jhein jhein is offline
Default Butler poly motor mounts
Anyone using these in a 70 TA? Do they require mods or are are they a direct fit?
I did a search here on mounts and they have an overall positive review but no mention of mods. Also, one person said they caught on fire? That doesn't sound great.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
Old 02-19-2022, 10:45 AM
JSPONT's Avatar
JSPONT JSPONT is offline
I use them on my A body. I had spoke to the guy who makes them. If they are close to headers, they need a heat shield. I used aluminum heat shield off a new car floor pan. not an issue yet. 7+years. the 1st 3 I had no mid plate and made 700+ hp, Now the mid plate helps them. JMO
The Following User Says Thank You to JSPONT For This Useful Post:
Old 02-19-2022, 05:50 PM
jhein's Avatar
Do you think they will be OK with RA manifolds? I have a set on order. Although I'm thinking now a torque limiter like a turnbuckle may be the way to go with stock mounts.
Something like these:
https://www.summitracing.com/parts/cee-4010
https://www.summitracing.com/parts/sum-770030
Old 02-19-2022, 05:55 PM
JSPONT's Avatar
Before the mid plate. I ran a chain to the frame. I got tired of it, and besides that, my car make a lot of h.p. so I did a mid plate. you have to see how close the heat is to the mount. If it is right next to it add a heat shield. If it is a few inches away, it should be fine.
Old 02-19-2022, 07:21 PM
SD455DJ SD455DJ is offline
I've had the Butler poly engine mounts in my 462 '70 Lemans with RA manifolds for the past 3 years and I don't even know they are solid. My engine is around the 450 hp/550 lb-ft level, so not too crazy, but it drives nice with them. Haven't melted either.
Dennis
