#41
Lots of guys use cast eagle cranks for pontiac stroker builds & other brands, yes there are/were a handful of problems with them early on... but again, you only hear about the small number of problems out of probably hundreds of thousands without problems. I would use a stock GM cast crank before a chinese cast crank though. |
The Following User Says Thank You to 78w72 For This Useful Post: | ||
#42
Yes that’s all fine, but when it’s your aftermarket cast crank that took out a short block that took you many years to save up for, then that’s not a small thing!
Maybe what needs to be asked here is for the folks who had one of those early aftermarket cast cranks fail on them did they on the next rebuild stay with a aftermarket cast crank, or step up to a steel one? I bet I know what the answer is.
#43
We've never had an overseas cast crank fail. We got two from an early batch that had the poor finish on the thrust surface and corrected that issue before using them. To refresh folk's memories here, Butler worked with Eagle to develop those cast cranks. They felt there was a need for them and had to buy a truck load to get them made. They sold that nitial batch of cranks at a much higher price tha they sell for today. Over the years the castings and finish have improved from the original. IMO there is still a place to use these crankshafts but I never felt they're for high horsepower builds. |
The Following User Says Thank You to PAUL K For This Useful Post: | ||
#44
There’s a market for them no doubt, when you know your market 95% is street cars, for guys who like to do burn outs and probably occasionally race just to see what she’ll do. Must likely 450-500 hp thats all done 5000-5500 rpms pump gas deals then those cranks will live. They know that if you say hey you need to go bullet crank $3200.00 then market drys up. Same thing with aftermarket blocks vs using stock block. Many of us had ran 10.30’s with stock blocks and cranks thats around 625 hp. And with iron heads that flowed maybe 265 cfm, but they peak at around 5500 rpms. So how hard is it to duplicate that not hard at all. Even street guys making that kind of hp who may make a few trips to track Will live. They know that, thats were the money is. Today thats what its all about mostly restorers looking for that muscle car they can take out and really enjoy after having a ton of money and years of planning and saving.
