#141
I'll get out soon and check those plugs in the oil gallery if I can
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
#142
Bench grinder stand
ANDRE 1972 TRANS AM , UNDER RESTORATION http://forums.maxperformanceinc.com/...d.php?t=656067 1972 FIREBIRD FUTUR PROJECT http://forums.maxperformanceinc.com/...d.php?t=674551 1978 TRANS AM (PARTS CAR) MAYBE 1971 LEMANS T37 (PARTED OUT) 1976 TRANS AM (PARTED OUT) 1984 6000LE (SOLD) 2003 SILVERADO 1500 |
#143
Now that's a damn good idea! I have a ton of bench grinder stands in my shed that I didn't realize what they were for! Thanks!
#144
WOW! We have pot holes in Detroit with smaller holes.
Tom Vaught
#145
plug I can see on the pass side is a hex
#146
hahahha
#147
#148
Just pulled the crank ,,,,,nice ...
I also noticed the rear cam bearing is not installed flush is cock-eyed....its worse than the pic shows
#149
The rear cam bearing will not sit flush. It will stick out a little in some places. The oil hole has to line up.
#150
ah,,,ok
#151
Maybe a dumb question but I see you are running solid roller lifters on a hydraulic roller cam.
I know that if using regular solid lifters you have to use restrictors in the lifter bores or smaller hole pushrods to decrease the amount of oil that goes to the top end. Is this the same for roller lifters or do you already have restrictors? |
#152
Just throwin' this out there. New crank dont mean anything to me. Just reground a new 4.25X3.00" . Not concentric, not round, some barrel (.0003"') and some tapper on the rod thows. Stroke index was out and a little large on stroke. Took .0107 off the NEW crank. New bearings yada yada. I am happy with it now.
#153
#154
#155
I have built a lot of Pontiac's, including 455's that rev to 7200rpm's, and 541's that rev to 7800 rpm's or more. I don't use restrictors in anything. I have never had an engine suffer from a bearing failure. This failure is NOT from not running restrictors. Cleanliness, bearing prep, and good oil is the key to happy bearings.
#156
Well we are on the road to Resurrection .....All my parts for the rotating assembly are in hand and off to Machine shop Sat.......the process begins.......
One quick question...my old ( 1500 miles) balancer and flexplate ...is there any value to them since they have been " adjusted " to match my original crank or are they door stops..???
