Can you give any cam specs, compression?
can i have naked pictures of your girlfriend or wife?
John great numbers. Hope to see you at the RAM race at cecil on July 15th..Maybe we can make an all PONTIAC final in all classes!!!!
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046 jet First ultra street/ultimate street NOS car to get into the 4's! 1.079 4.559 153.23. 3100 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! T2TTFMF! Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
John, Congrats on your numbers! How does our Uncle Tony do it...I mean he's not a pontiac guru or nothin'? LOL! Can you bring that cross-member to Cecil? -Brian
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
remind me the day or so before the race so i can put it in my trailer. Imagine how much power he could make if he specialized in Pontiacs.
ok...I'll do that.
I know it's scary what he could do if he concentrated all of his efforts to pontiacs. -Brian
put alot of people out of business
John at that hp level, how many runs can you put on it before it need attention.
Rex |
If he started just concentrating on Pontiac then his powered levels will start going down. If you get tunnel vision like alot of the Pontiacs guys have then you dont see what the other brands are doing to increase their hp levels.
Hows that cam idle? does it have a nice rumpity? can I use that one ok with my power brakes?
Define need attention? The car idles at 700rpm in gear with a 1050 dominator.
i think what he means is how often do you have to adjust the valves (after every pass i would guess), have the heads off for new gaskets, etc.
I check the valves every pass as preventative maintenance. I would rather prevent a problem then discover one. New head gaskets every 25-30 passes.
This "Uncle Tony" sounds like the guy I wish I had build my motor - live and learn. Anyhow, FWIW from a relative newcomer: very nice indeed, congrats. Mark.
Ain't as good as I once was, but I'm as good once as I ever was. |
John
Your persistence is admirable,Nice results for a mid-season tune up. P.Stk. has been good this year and this will make it better,Good luck.
Gary Kubisch |
Stags,
Here's BES's web-site. I'm not sure how current it is, but nonetheless, it's info. if you need it. -Brian
#38
bad69bird - the link didn't come up for some reason so please post it again if possible. Paul Spotts is another guy I should have called but now I'm just gathering info for the next time - there's always a next time. Thanks, Mark.
#39
#40
Cecil Co. on the 15th?! Good deal. I have enterd a Nostalgia Super Stock Race to be held at Cecil on the 15th.
I'll get to see that bad boy of John's run ... Scott R. are you coming to ??
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
