Old 04-23-2021, 06:07 PM
johnta1 johnta1 is online now
I'm unfamiliar with the high ports. Are they the root cause of the mis match? Not designed for a standard intake?
The high ports are a taller head. With it being taller, the crossover from the timing cover to the normal intake water crossover is out of alignment.
Would require blocking the port holes on the crossover and the timing cover. Or use the KRE crossover, which requires cutting the stock one off the intake. (as done here)
The high ports have larger intake ports which requires matching to the intake. Most stock type intakes will need work.
Hopefully the OP does not have a flat hood!
Old 04-23-2021, 06:25 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I think I mocked up HP vs stock heads and an intake sat at least 1" taller.
Skip Fix
Old 04-23-2021, 07:04 PM
Skip Fix's Avatar
And remember the 409 Z-11 heads were the first High ports. McQuillen's aluminum version!
Name:	Z12 head 3.jpg
ID:	565264   Click image for larger version
Name:	Z11 head cropped 2.jpg
Skip Fix
Old 04-24-2021, 11:42 AM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
I have a 1000cfm Throttle body which is a smaller height than a carb. I had a huge air filter before so even if I had to lose 1" it wouldn't be a big loss for us EFI guys.
Looks like the Super Victor EFI might've been a better option and then I get new fuel rails. Well, that's why I'm in here, there's options to plan around beforehand, not get stuck in real time (though my machine shop did make the best out of this situation).
EFI Intake
https://www.summitracing.com/parts/e...5/make/pontiac
Rails for above
https://www.summitracing.com/parts/edl-3634?rrec=true
Picture of old engine combo below.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct at 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump
Old 04-24-2021, 12:38 PM
Scott65's Avatar
Scott65 Scott65 is offline
The SuperVictor probably would've helped with your problem. I had to mill .060 off for port alignment on mine, Edelbrock not wide ports.
Old 04-24-2021, 01:57 PM
Skip Fix's Avatar
Dang that one has gone up since I bought them for future use! I have a EFI T@ I had SD CNC for me too for possible use.
Skip Fix
