Mike Voycey made good power with them.
3250. With D Ports.
I know he is 3700. But he has RA IVs. Still can be done. My buddy is running 10.0s with #62 DPorts, at about 3600. All steel 66 Tempest. Like I said, its the whole combination.
1978 Pontiac Grand LeMans.......out next year Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs. |
Hasn't Jim R. Made some big Hp with iron heads?
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
Jim runs 48 that flo 300 I believe.Tom
in 2000 I made 725 with a 469. don't remember the stroke. victor intake and a dominator. 1.65 harland sharp rockers. went 9.20's in 2350# tube chassis car. put them on another shortblock and went 8.90's
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1 |
I got the Warrior intake from mike. He did a lot of work on it. He does really nice work. The ports are about 1/4" shorter than on the heads though.
Would I be better off switching to a northwind ported to match the flow of the heads? I'm going to switch from 1.5 to 1.65 rockers before spring. My heads have a four digit numerical code stamped into them. Anyone have any idea what head porter may have done this to heads they ported?
You should get his input on the heads..he ran 9.40's with RamAir 4 heads. I was lucky enough to purchase a shortblock from him.
Remember Ace at PPR. He had a Warrior that Gabby welded up the plenum and gave it more volume.
It ran 9.30s in a heavy 2nd gen with mildly ported E heads done by Dave at SD. 290cfm. On a 400. They can run, were designed from the start to use spacers for more plenum. Not much room on a Warrior to raise the port 1/4" though, close. |
You can't get the needed port runner taper out of a warrior when starting off with ports made that tall like that at the flange without tons of welding, and then after that as posted your Plenum volume is too dam small!
A Wenzler 2-4 tunnel ram would be my pick for what to start off with in terms of a serious combo like this.
That's true tommy.
Maybe I should have posted how fragile your hands and wrist are after porting a iron Head out to big killer flow numbers, lol! Yes, you & your dad bring yourselves and some nice hot NYC bread out to Norwalk please!?
Northwind intake is also a good choice
Carburetor building & modification services Servicing the Pontiac community over 20 years |
Factory rating, + a little..
