#461
JC, Jack said it was an option.
#462
#463
That was good of you to put your figure up to show just how inaccurate you are on these sort of things! You honestly believe that a overhead valve traditional American V8 with pushrods makes over 3 horsepower per inch??? I appreciate you showing that you know absolutely nothing about these type of engines and their applications. By the way... you should NEVER figure horsepower off of ET. Just wow!
Life is hard, it's even harder if your stupid- John Wayne |
The Following User Says Thank You to Daniel Barton For This Useful Post: | ||
#464
OK fellas, What do you think these heads would do in very high effort power plants like Rodney Butlers, the Dirty birds or John Welters.
Boosted to the max. Maybe the added head bolts for extra durability ? How much HP does it take to be "all in" in Pro Mod ? 3500- 4000 ? And could the current blocks take it. I know the MR1s experience cap walk at very high HP levels. And if they do the AP blocks certainly do since they are basically the same block. These heads on a new Pontiac block with priority main oiling, larger and higher cam tunnel, somewhat shorter deck and a LS1 style cross bolted mains. Just might be the ticket. Hey, at this point I would still call it a Pontiac, why not. There is room for both. The iron heads and RAIV cam guys and this. Visner said he had a non canted valve Pontiac head on one post. The head I would like to see is a Pontiac head that takes a standard Pontiac valve cover, inline valves and RAV exhaust location. Just put the intake ports/ runners where they need to be to make the most power with the room you have without any pushrods going through the middle of them. At least it would "look" like a Pontiac. |
#465
7000 posts to look through, I don't know it was right there.
#466
Visner thought it up.
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
#467
I think that these heads would rock and roll in a blower combination. They would also help a turbo combo, as well...but not as much as a blown combo.
We've had a grand total of zero head gasket issues since we went to the added head bolts on the E head. The billets might not even need the extra studs, especially if you had room around the stud to go to a 9/16" stud like Eric and Mike did with their Fives. That would sure be an added bonus...less crap to deal with is always a good thing. |
#468
10 head studs is plenty if you have a stiff enough head to bridge between them....and spread the combustion loads to more than just the 4 closest studs. Boss Bird has zero head gasket leakage and we're still on our first set of copper Flatout gaskets..
Eric
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. “The mind, once stretched by a new idea, never returns to its original dimensions.” Last edited by Elarson; 12-23-2013 at 12:29 AM. |
#469
The Visner billet heads look pretty stiff and I think they'll probably seal great.
Eric
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. “The mind, once stretched by a new idea, never returns to its original dimensions.” |
#470
Why not on both?
#471
[QUOTE=Daniel Barton;5091717] You honestly believe that a overhead valve traditional American V8 with pushrods makes over 3 horsepower per inch??? /QUOTE]
http://youtu.be/HihdoLYhWy8 ... this one makes right on 2.9 per cube ... |
The Following User Says Thank You to twinturrbo406 For This Useful Post: | ||
#472
[QUOTE=twinturrbo406;5092090]
Yes we make 1140-1150 with our ANDRA pro stock stuff. Those are some sweet little smallblocks. Jack
Visner Engine Development, LLC. |
The Following User Says Thank You to cptinjak For This Useful Post: | ||
#473
Would definitely pick both combinations up, no doubt.
Blown engines rely a great deal on the ability of the cylinder head and camshaft to move air through the engine; the compressor is tied to the front of the crankshaft. With a turbocharged combination, the air compressor is not tied to engine speed, so there is a little bit more latitude with what we can get away with. You will see a lot of folks that say "bolt a bigger head on, and you'll make more power with less boost". Most times, that is a fact with a blown combination. And most (not all, but most) times, that statement is total fiction with a turbocharged engine. They are two totally different animals that are typically run in different ways on the racetrack. |
#474
cptinjak, thanks for the info on your head.
How long did it take to make Jack's head? He said 3 1/2 months, but that seems long for a CNC'd head. Also, the head still needs port work when you're done maching it? It looks like a great head and will make some serious power.
#475
#476
As I said before it would have been done in three months but there was an issue with one of Davids machines. David said he could finish the ports, but Gaby wanted to finish them his way specifically for a PA car.
#477
The Following 3 Users Say Thank You to Scott Roberts For This Useful Post: | ||
#478
Let say...these heads set the pontiac world on fire....would visner ever consider casting these heads for the common folk?
Thanks, Tom Syron |
#479
Cast iron cylinder head cost point can be reduced based on the number of units sold, so like any business man would ask, how many cast units could be sold? High end production cast cylinder heads from Profiler, Dart and others for BBC and SBC would range from $5,000 to $8,000 ready to bolt on, so how many sets of Pontiac heads could be sold in a year at those price points? Add new manifolds, valve covers and other items and the cost to change over a race engine would be around $10k to $13k. Calvin Hill Hill Performance 708-250-7420 |
#480
Jack
