Comp Cams 221-4 cam
Has anyone used the Comp Cams 221-4 cam and what do you have to say about it?
Sent from my SM-N950U using Tapatalk |
About the only place you could effectively use that cam is in a 350 build with low compression. Not nearly enough cam for the larger engines especially if they have some "squeeze" in them.....IMHO....
The Following User Says Thank You to Cliff R For This Useful Post: | ||
Considering it for a lo compression 8.6 400 in a full size wagon. A cruiser. Also considering a Pontiac 066 and a summit 2800.
It's a good step up from the factory 2 bbl 254 Cam in terms of lift and mid power, and a very mild step up from the factory 066 Cam.
I do stuff for reasons. |
The Following User Says Thank You to 25stevem For This Useful Post: | ||
I used the old Comp 252H cam in an Olds 350 back in the day. Ping monster. The old worn out factory cam was better. This was a `77 low compress 350.
Just sayin... |
Stan
The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
Yep. That`s where I was going. Especially with his closed chamber heads. 2800 a much better choice AND 1/2 the price of the Comp. |
definitely apples and oranges, but i ran a 350 chevy with 041 iron heads and a 216@.050 crane fireball on 93 octane with no problems for years. an 8.6 to 1 iron head engine is going to ping with this cam? i understand the XE grinds tend to build compression but wow, I would not have anticipated a problem with that low of a compression ratio!
isn't an 066 around 200 @ .050? an XE grind with an extra 12 degrees of duration at .050 will build more cylinder pressure than the 066? |
The Following User Says Thank You to i82much For This Useful Post: | ||
Stan
old faithful runs great for me. no idea if another cam would be better. monkey see, monkey do right her but i wouldn't change a thing. sometimes it is better to just go with the wisdom of the crowd instead of trying to be clever and do your own thing. if i was the OP i'd probably do the 2800. |
" i ran a 350 chevy with 041 iron heads and a 216@.050 crane fireball on 93 octane with no problems for years"
It should have been fine on pump gas with that combination. The Crane Fireball cam will have a LOT of seat timing, considerably more than 256 @ .006". The SBC 041 heads have EXCELLENT close chambers and if you did what the factory did and ran flat top pistons about .015-.018" in the holes at TDC and .020" steel shim head gaskets it would have ran flawless on pump gas and may not have even needed 93 octane with "normal" timing/fuel curves.........FWIW......
The Following 2 Users Say Thank You to Cliff R For This Useful Post: | ||
looking at the comp master list. i think that intake lobe on the cam in question is 5441, 256 advertised intake duration and 212 @ .050. the difference between advertised and .050 is 44 degrees.
looking at the high energy hydraulic flat lobes, there are three lobes with 212 @ .050 duration, 5211, 5205, 5207. all three have advertised durations of 260 degrees. so the difference between advertised and .050 is 48 degrees. so that's only 4 degrees advertised duration difference between XE and high energy lobes with the same .050 duration. the summit 2801 is 214 @ .050 and 288 advertised, or 74 degrees. it seems like the comp high energy lobes should cause almost as many problems as the XE lobes? |
it looks like that crane I ran with 216 @ .050 was rated at 290 degrees duration. that sound so big! but it was just a pussycat daily driver, really, probably a smidge tamer than OF 1.0 in my current 505.
Stan
I believe the only open chamber `67 head is the 061.
The Following User Says Thank You to PunchT37 For This Useful Post: | ||
Again it may be my lack of knowledge but they have 90cc chambers (8.6:1 c.r.). Please excuse my ignorance. I am here to learn.
The 142 head is not a open chamber head.
The 142 and 143 casting where still a 389/421 17 degree valve angle head. 1967 is a very confusing year in that Pontiac had 3 different chamber shapes being used. Still your better off then if you had the 061 head, as that chamber is very detonation prone.
I do stuff for reasons. Last edited by 25stevem; 07-30-2022 at 01:52 PM. |
