Old 04-11-2019, 09:34 PM
84TA400 84TA400 is offline
Default Oil filter AN line size
What size AN line should be used for a remote oil filter setup. 80psi pump, wet sump, thanks
1984 TA, 400 PONTIAC, th-400, 4.10 12 bolt
10.49@ 127mph 1.40 60'
R/U Pontiacs in the Park 2006(SAT)
R/U Pontiacs in the Park 2007(SUN)
Old 04-11-2019, 09:55 PM
J.C.you's Avatar
J.C.you J.C.you is offline
I use 10 on multiple apps and keep the remote and filter as low as possible.
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
The Following User Says Thank You to J.C.you For This Useful Post:
Old 04-11-2019, 10:28 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
# 10 on mine.
The Following User Says Thank You to Scott Stoneburg For This Useful Post:
Old 04-12-2019, 01:18 AM
Lee's Avatar
Lee Lee is offline
agree on at LEAST -10
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
My webpage http://lnlpd.com/home
The Following User Says Thank You to Lee For This Useful Post:
Old 04-12-2019, 02:15 AM
92GTA's Avatar
92GTA 92GTA is offline
Same here, lines off my AMSOIL housing are -10 AN, fittings on my oil thermostat are -10 AN, and fittings on my oil cooler are -10 AN.
1969 Pontiac Firebird
Old 04-12-2019, 08:22 PM
Looks like 10 it is, thanks
Old 04-13-2019, 06:03 AM
taff2's Avatar
taff2 taff2 is offline
AN12 on mine, less pressure drop if you have long lines
Old 04-13-2019, 06:49 AM
steve25 steve25 is offline
Are you running the lines off a adapter block , or have you done the more work but better way of drilling and taping the block for 1\2" pipe?
If your drilling the block you can go into the return hole with a grinding Burr and put a nice funnel shape taper in there after the threads end.
A 6 long Burr will also allow you to get in deep enough to round over the inside bend of that passage where it turns up to the front of the block.
Old 04-14-2019, 05:06 PM
455-4+1's Avatar
455-4+1 455-4+1 is offline
-12 for me but with oil pump and filter up front we had long line lengths
Also enlarged passages in the block etc and oil pressure measured at the front main out through the face of the block (smaller line in pic)
Accumulator to enlarged feed hole by dizzy and you can see -10 drains to pan from the back of both heads
ID:	510117   Click image for larger version
ID:	510118   Click image for larger version
Working on going faster (and now staying dry at the same time !!)
Old 04-14-2019, 05:10 PM
GTOGEORGE's Avatar
No. 10
GTO George
Old 04-15-2019, 12:56 AM
92GTA's Avatar
Bottom line is, there is only sense is having it as large as the smallest AN fitting any of your hardware should have based on its ID. Otherwise, you are overbuilding it just to have a bottleneck.
Old 04-15-2019, 01:54 AM
455-4+1's Avatar
Agree, but if line lengths go up or tighter bends required by physical constraints, i would upgrade fitting size and line size to suit, while utilizing full rad bends where possible. Losses through a long thin lines will be higher.
My HP6 filter housing and oil pump all acept _12 fitting so block adapter was made to suit with main gallery enlarged to suit.
Old 04-01-2023, 02:43 AM
R 70 Judge's Avatar
Just piggybacking off this thread as I’m having a hell of a time getting the dual -12 AN hose fittings to fit. They interfere with each other when trying to tighten the lines at the remote housing on the block.
I’m using:
Any suggestions? I know a few board members here have run -12 lines. How did you make it work?
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 04-01-2023, 07:28 AM
chuckies76ta's Avatar
James, Wondering if you have enough room to install an adapter on one of the holes to offset each fitting. Something like this. https://www.amazon.ca/Gsinodrs-Fitti...22697296&psc=1
Only other way to spread them apart some is to make your own adapter and have the threaded hole tapped on an angle like 10 to 15 degrees. Very easy to make out of aluminum.
I though you were running an IA2 that is already threaded for fittings? But I do understand how close the holes are to each other.
Old 04-01-2023, 07:43 AM
mysticmissle's Avatar
Default pics of your system
any pics of your set up installed? I am going to run clear view with the built in filter and with a moroso accumulator this go thru
QUOTE=R 70 Judge;6417980]Just piggybacking off this thread as I’m having a hell of a time getting the dual -12 AN hose fittings to fit. They interfere with each other when trying to tighten the lines at the remote housing on the block.
I’m using:
any pics of your set up installed? I am going to run this with a moroso accumulator this go thru
Any suggestions? I know a few board members here have run -12 lines. How did you make it work?[/QUOTE]
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 04-01-2023, 08:01 AM
I was thinking another way to do it is have a really good Aluminum welder, weld the fittings on for you. I had my Son weld these to a manifold cross-over. There is a thicker Aluminum oil adapter someone sells. https://www.summitracing.com/parts/c...9/make/pontiac
Old 04-01-2023, 08:05 AM
Elarson's Avatar
Elarson Elarson is offline
I’m using:
I don't have direct experience with that adapter and -12 fittings. But based on some games I've played with hydraulic systems....could you put a short piece of 1/2" pipe in one port and then a female pipe-to-AN fitting on it....effectively staggering the -12 fittings?
FWIW,
Eric
Old 04-01-2023, 08:31 AM
Formulas Formulas is offline
If you manufacture your own block adapter you do not have to come straight out just like a tapped engine block, the lower fitting can come out of the block adapter at different angles to avoid fitting to fitting problems
I did a 90° turn in the adapter then a 45° elbow at exit, and no this turn did not adversly restrict flow, alot of flow area in the turn
Old 04-02-2023, 01:42 PM
R 70 Judge's Avatar
I could have a billet adapter made with one of the holes slightly angled but I don’t want to invest a bunch of money on a one-off piece. It seems the majority of Pontiac guys are running -10 instead of -12
FWIW,
Eric
This is going to be the plan. To weld on some type of extension to offset the fittings.
James
1970 Trans Am
Old 04-02-2023, 01:44 PM
R 70 Judge's Avatar
I could have one made on the cnc but it would be expensive
James
1970 Trans Am
