Does anyone sell them. All I see is main studs.
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
Are you running steel caps?
yes factory caps
You can buy ARP bolts in the correct length -most any length-but under head they are slightly smaller OD than the factory bolts so there is the potential the cap could move. i have heard some guys machining the caps for shouldered washers from ARP to do that.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune 13.43@103.4-sold 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
If you’re running only two bolt caps and have the stock bolts just reuse them if they have no rust on the threads.
The stock bolts are far stronger than the stock iron caps are, (even the factory Armasteel 4 bolt caps) The caps will go south first. Even if you where able to get new stronger bolts or use studs the line bore would need to get check to see if a line hone job is needed because stronger fasteners will pull on the main webs differently.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 02-09-2025 at 06:46 PM. |
Here are a couple sets for D-ports and for E-heads:
https://www.jegs.com/p/ARP/ARP-High-...&submodel=BASE
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion 2024 Chief of the Pontiacs |
He’s looking for main cap bolts not head bolts.
The Following User Says Thank You to steve25 For This Useful Post: | ||
Thread Tools | |
Display Modes | |
