Old 10-12-2017, 08:43 PM
crm318 crm318 is offline
Default How do you run a fuel pressure regulator with steel fuel lines?
I just ordered a steel fuel line to replace the rubber that I have in place between the carb and fuel pump. How are you guys utilizing a fuel pressure regulator with steel fuel lines?
1970 GTO: Atoll Blue, TH400, 400 +.060, small chamber Ferrea big valve fitted # 15 heads, Summit 2802 cam, Iron intake, Cliff Ruffles 850 cfm qjet, Hooker headers, 2.5 mandrel bent exhaust, Race Pro mufflers, 3.73 Safe-T-Track.
Old 10-12-2017, 09:43 PM
Tom Vaught's Avatar
Boost Engineer
I assume you want to add a pressure regulator in the circuit from the mechanical fuel pump to the carb, correct?
What size is the steel fuel line?
Tom V.
Old 10-12-2017, 09:46 PM
Will Will is offline
I bend my own.
Yes. It is the stock 3/8" line.
Old 10-12-2017, 10:32 PM
NeighborsComplaint's Avatar
Remove the metal fuel line and cut with a tubing cutter in a straight section where you want the regulator, removing a length the same distance as the distance between the in and out ports (assume inline regulator like Holley). Purchase 3/8" tube nuts (available at NAPA.and slide over the ends of the tubing, Flare the tubing ends with a flaring tool and reinstall. Tubing cutters are available at the hardware store and Autozone loans flaring tools.
Depending on your regulator, you may/may not need adaptor fittings from your local NAPA.
You can dead head the regulator (no return line) with a mechanical pump even if the pump does not have a return line to the tank.
Old 10-13-2017, 06:35 AM
Tom Vaught's Avatar
Boost Engineer
Knowing the regulator you plan on running would help with performance expectations and further advice on the regulator plumbing.
Tom V
Old 10-13-2017, 07:18 AM
steve25 steve25 is offline
First off are you running a electric fuel pump that is calling for this need for a regulator, and also what make and model regulator are you installing?
Old 10-13-2017, 08:10 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Most of the regulators will have NPT threads, 3/8" is the most common. Larger high flow regulators typically use 1/2NPT.
You simply need to get two 3/8" NPT adapters to 3/8" inverted flare (for example), which actually will measure 5/8"-18 for threads if memory serves me correctly. Cut and flare as noted above and make sure to "double flare" or the vibration will cause the lines to break.
Nothing at all wrong with using a pressure regulator with a mechanical pump, some put out pretty high pressure especially currently available stock type pumps as there doesn't seem to be any industry standard for those parts these days and most are off-shore production.........Cliff
Old 10-13-2017, 06:22 PM
I am using a mechanical pump, but I have a Carter electric thst im thinking of using. Here is my regulator.
Old 10-13-2017, 08:01 PM
Tom Vaught's Avatar
Boost Engineer
Hope you are not planning on any performance work with your engine and that regulator.
I am sure that it would regulate fuel pressure on a stock engine application.
With a performance application that specific regulator would have a hard time flowing enough fuel to support any added HP. The restriction inside is .220.
In the old days, guys used to have to use one regulator for each bowl to keep the fuel bowls at the right fuel level under WOT conditions.
Which electric fuel pump were you thinking about using?
Tom V.
Old 10-14-2017, 01:47 AM
I may just remove the regulator all together and see how it runs. This is the electric pump I have.
ID:	465340   Click image for larger version
ID:	465341   Click image for larger version
Old 10-14-2017, 10:17 AM
Tom Vaught's Avatar
Boost Engineer
Well at least you have a decent fuel pump (carter 4070) as a pusher pump.
They work good on a honest street car. The electric fuel pump being a 4-6 psi pump
may work fine under a higher fuel demand situation, as far as moving fuel forward to the mechanical fuel pump.
Good luck with your street project. Electric pump is nice for priming the carb with some fuel before the initial fire-up. Today's gas disappears in a week or so if the car sits without being fired up. The Holley regulator would work ok with the street fuel system you are proposing.
Tom V.
