Rough idle, barely runs in gear.
The other day, I took my GTO for a cruise. It ran well, but near the end of the drive, on a 60 mph highway, it got up near 230° for a very short time. A week later, I started it up and it would barely idle until warm (90° out here) but it eventually ran decent. I also installed an aluminum radiator during that week. Today, it wouldn't idle without feathering and steady pedal. I installed a new Cliff Ruggles Quadrajet and it still has the same symptoms. It even puked a little gas on start up. It acts as if there is a vacuum leak, however, I blocked off all vacuum sources to the carb and sprayed starting fluid around the base with no variation in rpm. At idle, it has an unhealthy lope and it won't even run in gear without getting on the stall. Sun Tuned distributor is set at 12° degrees initial and 32° total. 5.5 psi to the carb. Could I have burned something up on or in the engine for the short time it was at 230°? Seems unlikely, but I am stumped.
1970 GTO: Atoll Blue, TH400, 400 +.060, small chamber Ferrea big valve fitted # 15 heads, Summit 2802 cam, Iron intake, Cliff Ruffles 850 cfm qjet, Hooker headers, 2.5 mandrel bent exhaust, Race Pro mufflers, 3.73 Safe-T-Track. |
Have you rechecked the timing?Sometimes if not tight they can retard themselves.Tom
X 2.
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
Yes sir. 12°. I also made sure the hole down bolt was snug.
I'm no expert but could it be a lost lobe on that HFT Cam?
Karl |
You may have a failed head gasket. I would suggest doing compression test and check radiator for signs of gasket failure.
Explain more.^ Does It run normal off idle,also running under load? (cruise ) Any new mechanical noises? Any idea why it got hot? What does it normally run rolling? Possibly detonation/damage from a load of poor fuel? Not clear if only has this issue @ idle /low rpm only. Ether terrible for pinpointing vacuum leaks, too volatile, propane works well.If simply closing the choke manually cleans it up then a vacuum leak. idle mixture screw adjustment a distinct possibility? Myself plugs out, see what they say. If it will run at higher rpm, Turn up the idle and pull one plug wire at a time and replace, note if no RPM drop, weak hole and where to look deeper.Also note if you have a nice fat long spark, make that coil work hard. Could it be as simple as a leaky set of plug wires? Runs bad on damp days. Need to determine if you have a dead/weak hole/s if a few are they grouped by the intake divide, adjacent to each other ,or are they all affected. Last edited by STEELCITYFIREBIRD; 10-04-2017 at 09:56 PM. |
Puking gas at start up is a sign of retarded Cam timing , or the firing order being wrong, and both will make for poor idle and low Vacuum!
rough idle
I'd pull the plugs first, if anything's going on with an individual cylinder the plugs should show it. If they're all dark, you've got a ignition or fuel issue. If one is extremely clean compared to the rest it probably is the head gasket. Do a compression test as well.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
The plugs should be very telling. |
Here are the plugs. They all look decent (#2 is a bit dark, but not bad) but #7 looks suspiciously clean. I did just put on a fresh set of rebuilt heads with Cometic MLS Head Gaskets C5711-027. No oil loss and the coolant is clean and full. Cylinders were in perfect condition when I replaced the heads.
Compression test at 190° temp: 1) 127psi. 2)125psi 3) 127psi. 4)135psi 5) 140psi. 6)135psi 7) 123psi. 8)123psi
1970 GTO: Atoll Blue, TH400, 400 +.060, small chamber Ferrea big valve fitted # 15 heads, Summit 2802 cam, Iron intake, Cliff Ruffles 850 cfm qjet, Hooker headers, 2.5 mandrel bent exhaust, Race Pro mufflers, 3.73 Safe-T-Track. Last edited by crm318; 10-05-2017 at 02:43 PM. |
Pull the plug wire on #7 and see if it is doing any work....rpm drop. Clean #2 up before it goes back in...or move it to #7. Go from there. Most are pretty low #'s, valve adjustment too tight?
Those cranking numbers do seem low. After you do the suggested test for a weak/dead cylinder, do a leak down test. I suspect you will find one or more not sealing up good. Good luck and do let us know what the actual cause is.
Well, at this point, I would assume that if there was a flattened love, there should be metal particles in the oil filter. I just purchased one. I'll put it on the morning and cut open the old one.
Do you have any noise in the valve train?
Karl |
No valvetrain noise at all.
I would check valve/rocker adjustment.
I like 1 turn preload with standard 951 lifters from zero play at pushrod. |
Well, I figured I would put on one of my old plug wires on the #7 and it is back to normal. So much for the brand new Taylor Cable wires. I took it for a cruise and the Cliff Ruggles carb is amazing. I will borrow my buddies more competent Snap On compression tester and continue my investigation. I'll keep y'all posted.
Karl |
I was able to get my hands on a Snap On compression tester and the numbers jumped up from 147 to 155 psi. My old tester is going in the trash...
