Old 09-01-2017, 08:09 PM
crm318 crm318 is offline
Default Power steering whine after new pump install
I recently installed a new power steering pump on my 1970 GTO. There is a very audible whine, but the fluid level is up and the fluid is clear. Do these things need to be primed/purged? I recently replaced the power steering pump on my 72 Cheyenne and it did the same thung, but the whine eventually went away. Here is how the pum is oriented.
1970 GTO: Atoll Blue, TH400, 400 +.060, small chamber Ferrea big valve fitted # 15 heads, Summit 2802 cam, Iron intake, Cliff Ruffles 850 cfm qjet, Hooker headers, 2.5 mandrel bent exhaust, Race Pro mufflers, 3.73 Safe-T-Track.
Old 09-01-2017, 09:28 PM
77 TRASHCAN's Avatar
How long have you run it?
After install you are supposed to have weight off front tires, turn steer wheel from lock to lock to bleed out air.
If you've done this, and still have noise, get some Lucas power steering leak stop/conditioner, put about half of reservoir capacity in it, see where that takes you.
Shut it off
Shut it off
Old 09-02-2017, 08:59 AM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default regulator
My replacement pump made a whine as well. there is a special regulator
behind large nut that high pressure hose connects too. I swapped that regulator
from my old one to the new one and whine went away. Summit sells a kit with shims
which will set pressure output from pump. basically the replacement was over pressurizing
the system. I actually added shims from kit to reduce pressure which gave a better
feel for the steering. it originally felt too over assisted. kinda like driving on ice.
Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds
Old 09-02-2017, 03:46 PM
I have run it less than an hour. I will have to look into the additive and shims.
