Old 05-16-2017, 01:34 PM
crm318 crm318 is offline
Default NGK plug recommendation for iron heads
I am in the process of doing a top end swap on my 400 with flat tops and enlarged valve 1968 #15 heads. I am currently using AC Delco R43S plugs. I have heard good things about NGK. Do yall think it is worth the swap and if so, which NGK plug should I use?
1970 GTO: Atoll Blue, TH400, 400 +.060, small chamber Ferrea big valve fitted # 15 heads, Summit 2802 cam, Iron intake, Cliff Ruffles 850 cfm qjet, Hooker headers, 2.5 mandrel bent exhaust, Race Pro mufflers, 3.73 Safe-T-Track.
Old 05-16-2017, 01:42 PM
steve25 steve25 is offline
The 43s are a good heat range for your motor so if there in good shape save your bucks for other things.
Old 05-16-2017, 02:14 PM
They are. Only 2700 miles on them. Perhaps I should leave well enough alone, but we know that can be hard to do lol.
Old 05-16-2017, 02:39 PM
Right Steve. They are not big bucks, but I would not replace the AC's until you are just ready to replace them anyhow. I have XR5 (3332) installed but I dont think they have much selection for a cooler heat range.
Bill Nye.
Old 05-18-2017, 09:13 AM
A.W.Dille A.W.Dille is offline
I have NGK XR-4's in the GTO and XR-5's in the Grand Prix. Since going to them I won't use anything else in my Pontiac engines.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear
85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book.
87 F350 6.9 4 speed dually
A poor man has poor ways.
