Old 12-25-2016, 11:25 PM
crm318 crm318 is online now
Default What type of oil is used in a compression test?
I will be doing a compression test soon and I was wondering what type of oil is used to test the rings. Seeing as the cylinders are at a 45 degree angle, how do you get the oil evenly distributed around the pistons diameter?
1970 GTO: Atoll Blue, TH400, 400 +.060, small chamber Ferrea big valve fitted # 15 heads, Summit 2802 cam, Iron intake, Cliff Ruffles 850 cfm qjet, Hooker headers, 2.5 mandrel bent exhaust, Race Pro mufflers, 3.73 Safe-T-Track.
Old 12-25-2016, 11:29 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
Bring engine to temp. Turn off engine. Open throttle wide. Disengage ignition coil. Do compression test without oil.
Old 12-26-2016, 12:10 AM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
Oil is used when trying to diagnose a low cylinder.
Lets say one cylinder is at 50 psi. Add one or two spoon fulls of engine oil to cylinder then test again. If there is a substantial increase in compression, the piston rings would be suspect. If there is little or no increase, the problem would more likely be with a valve.
Then there are those pesky head gaskets. They can leak into the adjacent cylinder or into the cooling system.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 12-26-2016, 12:27 AM
STEELCITYFIREBIRD's Avatar
Regular motor oil, anything you would normally run. An old style pump squirt-er can, aimed appropriately and then rotating the engine a few times to distribute works well.
Compressed air works well for diagnosing major problems. Leakdown tester for smaller leakage, more precise diagnosis.
If the engine is still running, rpm drop by killing one cylinder @ a time, a cylinder balance test as it is called, works well for finding a weak lung/s and will show ignition and air/fuel supply problems too. The compression test will show if it is a base engine problem or ignition and/or air/fuel related.
Where to start the diagnosis depends on the symptom/s.
HTH
Old 12-26-2016, 04:47 AM
Schurkey Schurkey is offline
Yup. No oil.
If you don't have low cylinder(s), you don't need to add oil to the cylinder.
If you do have low cylinder(s), perform a leakdown test INSTEAD of adding oil to the cylinder.
Adding oil to the cylinder for a compression test is friggin' pointless. Either you add too much oil, which then jacks-up your compression pressure by adding a bunch of CCs of incompressible volume to the cylinder, or you don't add enough, and the leaking rings still don't seal, falsely indicating valve problems.
The leakdown test bypasses all the problems of "wet" compression tests.
Old 12-26-2016, 04:50 AM
Thanks guys. Yes, I meant in the event that there is a low cylinder. The engine runs fine, I'm just doing a check up. I seem to remember that the valves are adjusted to 3/4 turn past 0 lash. In the event that I removed 1/4 turn from that, do I have to go cylinder by cylinder in the firing order or can I just remove 1/4 turn from all cylinders at once?
Old 12-26-2016, 05:25 AM
You can just remove it from all.
Myself, I would run each to see where I was and then put them where I want to be....That's me.
Old 12-26-2016, 08:25 PM
Well, I got 125 psi on the number one cylinder. I will just wait and do a leak down test. The short block has 2000 miles on it and consumes zero oil. The spark plugs are have a reddish hue, but no oil or carbon. I lapped the valves on these heads and i remember having some thin margins on some of the seats. The motor runs and sounds great. It will obliterate the tires and and get squirrely on the first to second gear shift, but it does seem to lack some top end (could just be me). Im contemplating removing the heads and having a proper valve job done.
Old 12-26-2016, 08:55 PM
Compression pressure is affected by so many variables that it's hard to list them all.
125 seems low--what is your altitude? Engine cranking nice 'n' fast? Was the cam degree'd?
Old 12-26-2016, 09:13 PM
Spun nicely. I did not degree the cam. I also backed the valves off 1/4 turn (they were at 3/4) and no variation. I am at 2800 ft.
Old 12-27-2016, 04:33 AM
Originally Posted by crm318 View Post
Spun nicely.
Good.
Not the end of the world if the engine runs good otherwise. Since you're complaining of poor high-rpm power, it might have been nice. I'd also be looking at fuel pressure.
Shouldn't make a bit of difference as long as there's SOME lifter preload. Once you have "some", having more or less changes nothing in the way the engine runs except time between service.
I am at 2800 ft.
Yeah, 125 seems low. Gauge accurate? If it's the quick-disconnect style, they use Industrial Interchange (Milton "M") coupler plugs. If you build a test fixture using one or more of the "M" plugs, along with whatever plug fits "your" air system, you can use shop air and the gauge on the regulator to verify your compression tester.
Old 12-27-2016, 11:08 AM
track73 track73 is offline
I put together a real neat .040 over Chevy 400 with Olds rods. I ran it on my test stand to verify the engine integrity and break in the cam and lifters, I did a compression test with my new Harbor Freight compression guage and got reading of under 100 on all cylinders. I did the oil thing with no gain and was besides myself wondering what I did wrong. Then I spotted my Sun Compression guage and gave it awhirl. Well that was the problem . The HF guage was junk.
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
Old 12-27-2016, 03:45 PM
I just figured it was lacking on the top end because I assume that's where the cylinder pressure really starts to build. The fuel pressure regulator reads 5.5 and the qjet is filled with Cliff appointed components. It doesn't buck, surge or make any suspicious sounds, it just doesn't pull very hard. I'm also not sure if the valves are one or two piece, so it's probably time to go with some Ferrea's. Like I said, i remember my seats being a bit thin, so maybe it's a "few birds with one stone" situation.
Old 12-27-2016, 08:01 PM
Will Will is offline
You could be starving for fuel on the top end. Is your fuel pressure gauge where you can see it while driving? I had this problem at the track, the car would fall on its face near the top of 2nd gear. Turns out I was losing fuel pressure, which I was able to diagnose by mounting a fuel pressure gauge to the cowl so it stuck out from under the hood at the base of the windshield.
Old 12-28-2016, 02:16 AM
My gauge is under the hood, so I have no line of sight. My drop in power comes from when I shift into second gear (oddly enough, after I catch traction from shifting from first).
Old 12-28-2016, 02:36 AM
Try it on a full tank of gas and see what happens.
I found that my problems occurred with 1/2 tank or less. The fuel pickup was getting uncovered by the fuel sloshing to the back of the tank on hard acceleration.
Old 12-28-2016, 03:08 AM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
I always thought if the valve's weren't sealing 100%, than a compression check would show variances enough to warrant a leak down test.
I mean all 8 cylinders were lets say within 5 psi of each other than one would think it was awesome!
If one or more are I dunno 15-35 psi differences than one has to think that the valve sealing ability might be suspect. Of course rings could be suspect too.
So I dunno, I've never built engines before but if I did I'd totally expect each cylinder to be within 5 psi or dead on. I mean how many other builders here do a compression check right after building an engine, probably not many...
Keep me posted!!!
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
Old 12-28-2016, 03:18 AM
+1.....and the extra rear weight should help traction on the 1-2 shift!
Old 12-28-2016, 02:57 PM
Now you have another project: Move gauge to where it can be seen from the driver's seat, so that it's actually useful. AFTER you have verified fuel pressure through all your gears, at WFO and max power, you can remove it or put it back under the hood.
