Old 09-28-2016, 08:12 PM
crm318 crm318 is offline
Default Proper quadrajet base gasket needed
My 1970 GTO (with 400) has a late 70s smogger intake manifold that is very modified. Today, I replaced it with a period correct 1969 intake that is also modified (plenum is open like an edelbrock). I reused the base gasket and, with carb cleaner, found pretty good leak at the front. The base plate surfaces of the two looked similar enough, but it's just best to get a new one. Is there a prefered gasket for a stock iron intake? Also, is there a better way to find intake leaks than carb cleaner? I would hate to eat the new paint off of this one.
1970 GTO: Atoll Blue, TH400, 400 +.060, small chamber Ferrea big valve fitted # 15 heads, Summit 2802 cam, Iron intake, Cliff Ruffles 850 cfm qjet, Hooker headers, 2.5 mandrel bent exhaust, Race Pro mufflers, 3.73 Safe-T-Track.
Old 09-28-2016, 08:43 PM
ponyakr's Avatar
ponyakr ponyakr is offline
With the '68 & '69 intakes & Q-jets, I always used the 4-hole Mr. Gaskets.
http://www.jegs.com/i/Mr.+Gasket/720...N50aAqwc8P8HAQ
But, I assume that if the center is open, the open center Mr. Gaskets should work.
http://www.jegs.com/i/Mr-Gasket/720/56AG/10002/-1
Jeg's sells a thin one for $3.99.
http://www.jegs.com/i/JEGS-Performan...16125/10002/-1
But, there are all sorts of thicker gaskets.
The 60482 is 1/4" open center. Never used one.
http://www.jegs.com/i/Fel-Pro/375/60482/10002/-1
Butler sells a 1/4" thick open center SPM-68230.
http://butlerperformance.com/i-24850...ef=brand:99994
Old 09-28-2016, 09:15 PM
STEELCITYFIREBIRD's Avatar
Propane, with an on/off trigger button, or a smoke test machine.... if you have access to one.
Old 09-29-2016, 03:30 AM
Kenth's Avatar
Kenth Kenth is offline
I would use FEL-PRO60061-1 for 1968-74 Pontiac V8 intakes.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 09-29-2016, 05:04 AM
Cliff R's Avatar
Cliff R Cliff R is offline
We sell every Quadrajet base gasket currently in production. The correct gasket to use would depend on the carburetor number AND the intake it's being used on.
We help folks out with this situation all the time, we require the carburetor number and intake being used to supply the correct gasket.....Cliff
Old 09-29-2016, 10:47 PM
Thanks guys! I tend to use the thicker gaskets. I will look on your website, Cliff.
Old 09-30-2016, 05:42 AM
Cliff R's Avatar
We only have a couple of carb to intake gaskets listed. There are over a dozen choices and we stock all of them. My preferred gasket for the Performer, Performer RPM, and modified stock intakes is the 1/4" thick open gasket or the 4 hole with a small section snipped out between the secondaries.......Cliff
Old 09-30-2016, 10:49 AM
george kujanski's Avatar
george kujanski george kujanski is online now
I use a piece of vacuum hose as a stethoscope.....one end close to your ear, the other to sniff around the carb. You can easily hear a leak, that's how i found my leak.
george
Old 09-30-2016, 11:11 AM
78w72 78w72 is offline
dont mean to hijack the thread but quick question on this.... i have a SD ported cast iron intake with the notched rear divider on a e-head 467 stroker. what gasket is best for this, the open or snipped out 4 hole? is there a benefit to keeping the primary holes on the 4 hole gasket & just snipping the rear open vs just using a fully open one?
