Old 01-15-2024, 01:08 PM
crm318 crm318 is offline
Default Coil Placement
In I'm in the process of installing an Edelbrock Pro Flo 4 system and I am looking to place/install the coil. There aren't any spots on the back of the intake for the bracket to bolt to, however, it bolts to the back of the head nicely. Would this be an issue for heat soak?
1970 GTO: Atoll Blue, TH400, 400 +.060, small chamber Ferrea big valve fitted # 15 heads, Summit 2802 cam, Iron intake, Cliff Ruffles 850 cfm qjet, Hooker headers, 2.5 mandrel bent exhaust, Race Pro mufflers, 3.73 Safe-T-Track.
Old 01-15-2024, 02:57 PM
That’s perfectly fine to mount it there.
Old 01-15-2024, 04:29 PM
John Milner's Avatar
Believe some Pontiacs came from the factory with the coil mounted that way.
The Following User Says Thank You to John Milner For This Useful Post:
Old 01-15-2024, 05:06 PM
Thank you, Gents.
Old 01-15-2024, 11:37 PM
Schurkey Schurkey is offline
...but I'd absolutely move the fuel pressure regulator so it's not directly in line with the flywheel/flexplate. Then put the hoses inside the frame rail so they're somewhat protected from an explosion.
The Following 2 Users Say Thank You to Schurkey For This Useful Post:
Old 01-20-2024, 01:24 PM
gassman_67's Avatar
gassman_67 gassman_67 is offline
I use the PF4 also and placed my coil there. why did you not use the rail mounted vacuum reference regulator designed for the pf4?
https://www.facebook.com/KauffmanRac...6873234225938/
KRE 461,310 CFM 85cc, KB pistons, Eagle rods, Ohio crank KRE custom HR236,Dougs ceramic,Edelbrock Pro Flo 4. Quick Performance 9".
552HP 594 TQ
The Following User Says Thank You to gassman_67 For This Useful Post:
Old 01-21-2024, 12:30 AM
This was the regulator suggested and provided by my fuel tank provider, Tanks Inc.
Old 01-21-2024, 12:33 AM
My 1964 A-body V8 cars all came from the factory with the ignition coil mounted to the back of the passenger side cylinder head.
