Even if I took the Allen head out of the of the poly lock and ran the it all the way to the base of the thread, you still have .1" between the poly lock and the rocker ball. Since the Stover nut recesses upwards, you can run it down and it will contact the ball before it bottoms out.
1970 GTO: Atoll Blue, TH400, 400 +.060, small chamber Ferrea big valve fitted # 15 heads, Summit 2802 cam, Iron intake, Cliff Ruffles 850 cfm qjet, Hooker headers, 2.5 mandrel bent exhaust, Race Pro mufflers, 3.73 Safe-T-Track.
