Old 03-05-2024, 02:48 PM
sglemans sglemans is offline
Originally Posted by Schurkey View Post
That tube is the cold-air inlet side of the hot-air choke system. Filtered air is drawn down that tube, heated by the exhaust crossover passage in the manifold, and then pulled into the hot-air choke to warm the choke coil. There's a metered vacuum leak in the choke housing that causes the air movement.
Works great until the tube in the exhaust crossover part of the manifold perforates from rust. Then exhaust gas is drawn into the choke housing, which carbons-up the whole works and can promote corrosion.
The hot-side of the tubing can be attached to the choke housing with a special, high-temperature silicone hose, or be screwed-on with a tube nut and flare.
I've got a couple photos of the entire tube system, including one removed from a manifold--attached. First photo has an unfortunate shadow that makes it look like there's a double-loop of tubing sticking out of the manifold.
Thanks for the info, appreciate it! Here's what mine looks like at the current time
  #42
Old 03-05-2024, 02:51 PM
Now that you know what it is and what it does, do you still want to remove it and why
I would want to remove it if I went with another carb, such as Edelbrock etc.
if I stayed with the original AFB I would keep it, still deciding what to do thx
