Old 01-08-2023, 11:02 AM
joes455 joes455 is offline
I think your upper ball joint is not installed properly.it should be mounted under control arm
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 01-08-2023, 11:16 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Nope second gens on top of A arm.
Skip Fix
Old 01-08-2023, 12:11 PM
78w72 78w72 is offline
who is that directed at? if its regarding my pic, the bj's are definitely installed correctly...
Old 01-08-2023, 01:08 PM
P@blo's Avatar
P@blo P@blo is offline
Originally Posted by 78w72 View Post
all the above brands are very good but most are rather pricey for the average hobbyist & more geared towards racing. the best bang for the buck for any of these suspension parts is PTFB, they are very good quality & all they do is 2nd gen cars. they carry very nice upper/lower tubular A arms as well as almost any other part needed for upgrading these cars, very good priced kits as well.
i run their GT full front/rear spring kit on a 72 firebird as well as upper A arms with greasable bushings, subframe connectors & have teh G braces but havent added them yet. my car is more of a 3 in 1 build, mostly street but light duty auto x & drag strp use. very happy with PTFB stuff & dave knows these cars & will give great advice.
http://www.pro-touringf-body.com/
I'm with Blueghoast, very nice 78w72. I love the way these cars handle even with the factory stuff. Imagine the look on someones face when your 40+ year-old Pontiac can corner with their new vette.
Never heard anything bad about PTFB and will likely go that route myself. Just curious, what motor mounts are those?
Old 01-08-2023, 01:42 PM
thanks for the compliment. PTFB has very nice parts, as good or better than some of the bigger names but priced much better.
the mounts are just stock early style mounts before they changed to the later clam shell mounts. the early ones are much weaker than the later ones, i made my own improved version of a mity mount that has lasted for many years behind a 500+hp stroker engine on the street & dragstrip with drag radials running low 11's. added a limiter chain after a year or 2 for added safety/strength though.
Old 01-08-2023, 02:03 PM
I hope your correct with the ball joint mounted above assembly because thats the way i have mine installed.Just that every u tube video I've watched has it below
Old 01-08-2023, 02:12 PM
no need to hope, im correct.
what youtube vid shows a 2nd gen firebird/camaro with bj mounted on bottom of A-arm??
Old 01-08-2023, 03:35 PM
If your so correct ,why are so concerned with which video.?search youtube for 2nd gen f body.All the gm cars front end design are similar.Actually the load bearing and placement of the bj should be all typical.Personally I think it should go on bottom for that reason .I have mine on top like you.
Old 01-08-2023, 03:58 PM
not concerned with which video, was asking because i have never seen any 2nd gen with the bj on the bottom of the control arm in any pic or vid... but since you seemed so sure there are vids showing this i just asked you to post one.
not a big deal though, top mount is correct
Old 01-09-2023, 04:30 PM
blueghoast's Avatar
I beleive all BJ's are on the top a-boy x-body and even b-body.
I will check to be sure though just to know for sure myself.
GT
Old 01-13-2023, 11:27 PM
blueghoast's Avatar
GT
All the ones I looked at are as I said.
GT
The Following User Says Thank You to blueghoast For This Useful Post:
