Old 12-19-2022, 10:03 PM
joes455 joes455 is offline
Default 2.19 intake valve
I need a 2.19. and 1.77 valves in the length of aprox. 5.100 any suggestions?thanks
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 12-20-2022, 07:26 AM
25stevem's Avatar
25stevem 25stevem is offline
Butler has the exh valve in a race steel that is 5.110” in length.
Other then getting a custom valve made up this is the closest you will find, a the extra .010” of length can easily be ground off without cutting thru the harden tip.
Butler also has the 2.19” intake in the needed race steel, but it’s 5.275” in length.
Brodix has a 2.19” valve in a better 5.230” length and the tip length is .270” so I don’t know how that compares with the Butler valve.
Here again you could get a custom valve made by Ferrea if need be.
Manley could do the same for you.
I do stuff for reasons.
Old 12-20-2022, 09:13 AM
Half-Inch Stud's Avatar
I would let the extra 0.010" EXH length ride.,as usual the shims fix the spring pressure.
Custom by Ferrea (or top-shelf Manley) sounds excellent. Thanks Steve....HIS
Old 12-20-2022, 09:31 AM
PAUL K's Avatar
PAUL K PAUL K is offline
REV is usually the most economical choice for a custom valve.
MERRY CHRISTMAS guys!
Go fast, see Elvis!
Old 12-20-2022, 10:20 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Assuming 11/32 stem I think my Edlebrock 409 intakes were 2.19 5.100 ish. I can measure tomorrow I put stronger Manleys in using a solid roller in that motor. I used Ferrera 5.10-3 Dport Pontiac valves turned down to 1.72 for it. So might check Ferrera.
Skip Fix
Old 12-20-2022, 11:32 AM
Hey skip thanks I was looking at the same valves last night.the spec at .344 stem dia.I think my butlers 2.19 spec at 342 I may need to rehone the guides.Thanks for staying on track with the OP. H.I.S I dont have no idear what he is responding to,propable. to what 25steve stupid response was.In which has been removed.
The Following User Says Thank You to joes455 For This Useful Post:
Old 12-20-2022, 07:57 PM
Skip Fix's Avatar
https://www.summitracing.com/parts/e...make/chevrolet
Here s a Summit number.Ferrera does make some valves for Edelbrock but would not say which ones they make and are made to Edelbrock specs more like the 5000 series.
Skip Fix
Old 12-20-2022, 08:09 PM
jerry455 jerry455 is offline
I have a set of 2.15" for my Edelbrock heads that I got from Trend. I don't remember the length. I can check tomorrow when I go to my buddy's shop where we are building my motor.
Old 12-20-2022, 11:31 PM
Steve C. Steve C. is offline
Valve stem length for the 1.800" installed height on Edelbrock cylinder heads...
87cc chamber the intake is 5.093 and the exhaust is 5.110
72cc chamber the intake is 5.213 and the exhaust is 5.230
Old information here:
Old 12-20-2022, 11:49 PM
1.8 can GRIND down to 1.700 for benefits. 2.15 ought to answer the mail for a 2.19 valveseat....right?
While head porting, it just seems to me a valveset can be ground to match/complement the valveseat-height.
Old 12-21-2022, 03:47 AM
lust4speed's Avatar
At what point do you need to reduce the diameter of the exhaust valve? I'm thinking that my Edelbrock heads from Dave at SD came back with a 2.19" intake and a 1.72" exhaust and the valves were really close together.
Mick Batson
Old 12-21-2022, 07:46 AM
25stevem's Avatar
Edelbrock moved over the stock Exh valve position by .040" to make room for that big stock 1.92" Intake bowl throat ( 90.9% ) and to straighten out the Intake port.
A person who knows what there doing when porting these heads can in terms of a NA motor get all the Exh flow needed to have a good Exh to Intake ratio when using a 1.71" Exh valve.
A decent set of headers with the correct primary tube size will pick up the Exh flow level by 5% above .400"lift.
If you install 1.77" exh valves in these heads and run Pistons with a Exh valve notch cut for factory iron heads your going to run into problems when you attain a certain amount of lift .
The Following User Says Thank You to 25stevem For This Useful Post:
Old 12-21-2022, 09:12 AM
slowbird's Avatar
slowbird slowbird is offline
Unless it's a power adder build there is zero reason to install a 1.77 exhaust valve in an aftermarket Pontiac head. Biggest I personally would ever go is 1.720.
FWIW I made 1050hp na with a 1.700
The Following User Says Thank You to slowbird For This Useful Post:
Old 12-21-2022, 10:20 AM
Thanks HIS but no thanks cant shave the tips when using lash caps.Why is it so hard to just respond to the original post?My delema is to achieve my spring install height i have to shim my springs almost .200 and still have minimum coil .So hence the need for shorter valves,also using yella terra shaft 1.65 i have very little adjustment
Old 12-21-2022, 10:28 AM
Also to add to post just summited .,Changed to roller lifters that have almost .700 higher seat height then previous.,so trying to geometry correct without going to shorter pedestal s
Old 12-21-2022, 11:27 AM
Skip Fix's Avatar
There are some different thickness lash caps to jiggle height.
Skip Fix
