I think your upper ball joint is not installed properly.it should be mounted under control arm
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119 |
Nope second gens on top of A arm.
who is that directed at? if its regarding my pic, the bj's are definitely installed correctly...
Never heard anything bad about PTFB and will likely go that route myself. Just curious, what motor mounts are those? |
the mounts are just stock early style mounts before they changed to the later clam shell mounts. the early ones are much weaker than the later ones, i made my own improved version of a mity mount that has lasted for many years behind a 500+hp stroker engine on the street & dragstrip with drag radials running low 11's. added a limiter chain after a year or 2 for added safety/strength though. |
I hope your correct with the ball joint mounted above assembly because thats the way i have mine installed.Just that every u tube video I've watched has it below
no need to hope, im correct.
what youtube vid shows a 2nd gen firebird/camaro with bj mounted on bottom of A-arm?? |
If your so correct ,why are so concerned with which video.?search youtube for 2nd gen f body.All the gm cars front end design are similar.Actually the load bearing and placement of the bj should be all typical.Personally I think it should go on bottom for that reason .I have mine on top like you.
not concerned with which video, was asking because i have never seen any 2nd gen with the bj on the bottom of the control arm in any pic or vid... but since you seemed so sure there are vids showing this i just asked you to post one.
not a big deal though, top mount is correct |
I beleive all BJ's are on the top a-boy x-body and even b-body.
I will check to be sure though just to know for sure myself. GT |
GT |
The Following User Says Thank You to blueghoast For This Useful Post: | ||
