71 Muncie spline count
Time for a new clutch for me. I remember when I put one in 10-11 years ago there was a question on how many splines were on the 71 Muncie. I cant find my receipt from years ago, and a search turned up nothing. Anybody know?
Thanks!
71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs. 63 LeMans- 69 400 w/ original transaxle. 2.69 gears. |
26 count
Mark.. The Goat whisperer "I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered." |
assuming my memory serves me correct:
1970 & prior are 10 spline 1971 and later are 26 spline also; 1970 & earlier use a TH350 (small) output shaft 1971 & later use a TH400 (large) output shaft The only exception to this is Muncie three speeds - they retained the 10 spline input/small output configuration. This is why there appears to be some duplication regarding engine codes; 1971-1974 engines (1971-only for Firebirds; 1971-1974 for GTO/Lemans) destined to have a Muncie three speed had a unique code - to identify which clutch assembly the engine had installed... I may be wrong because this is a guess, but I think that Saginaw transmissions retained this configuration as well.
Thanks guys!
I was just going to use my old receipt to order the same parts, and I always save receipts!Just cant find it. Too long ago for Summit to look it up in their system also.
