Can anyone help me find the upper steering column bearing for my 1966 gto.
Also any advise how to change this would be helpful. ![]() Thanks... ![]() |
i think its part of the turn signal switch and is serviced as one.if its the same as 64/65.
http://www.yearone.com/yodnn/Technic...9/Default.aspx also you can buy the bearing here too fwiw
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines! 2006 silvy Z71 4X4,383 LS 600+hp NA Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-} |
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. ![]() |
Thank you guys for your help.... I did not know it was part of the turn signal switch...
Thanks again |
I've got a decent used one for sale under the 66-67 odds & ends for sale,
if you don't want to drop 60+$.
