Engine coatings continued.......
So a few years back we had a spirited debate about engine coatings. Seems a couple of folks were encouraging others to go out and spend $800-1000 coating engine parts with the promise that if they did they would stand to gain 50+ hp just by doing so....:
A fella entered the thread and proclaimed that he hoped they were right because they had just done it. He privately pm'd me and said he would be in touch with results. I'd love to hear more in this thread how that all worked out.
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
Well we know where this going.
Had several components coated with different types of coating(s) in a build prior to the discussion mentioned being originated.
Recent freshen revealed that the coating in the combustion chambers and piston tops was flaking off. Seemed more concentrated closer to the exhaust valve. Coating seemed to adhere to valve(s) well. Backside of exhaust were a PITA to clean. Most bearings looked good #1 rod coating was "wiped" clean full circumference of both shells in line with the oil hole. No scoring, the Coating material was sort of balled or rolled up. #2 main upper shell had the same condition starting. Didn't hurt the crank fortunately. Piston skirts showed normal type of indications of wear, slight scratches in bores. Coating in exhaust ports did seem to help get the heat out of the head, barely burns paint off the exterior of the head. Satisfied with that. Questioned the company that applied the coating(s), no help, sacrificial in some cases? Application process? Can't comment on any real power gains, but in comparison to others with similar type builds, any gain would be negligible at best.
Hmmmmm.
So not 50 hp. INTERESTING And the balling or rolling up on the bearings is the same we found. That's why we stopped running coated bearings. Ditto on pistons skirts and tops.
Coated with what? Moly? teflon?
Coating(s) Calico#'s:
Bearings and oil pump gears - CT1 dry film Windage Tray - CT5 PTFE Piston skirts - CT3 dry film Piston top - CT2 ceramic Chambers, exhaust ports and Valves - CT21 ceramic Wrist Pins and Oil Pump plate - DLC
A lit of money for hardly any return.
There's a proprietary polishing process for reducing surface friction while keeping super-precise dimensions. It's not a coating.
As for the combustion chamber & slug face...that's the Coating Topic i had assumed was in question for proclaimed HP benefits |
The Following User Says Thank You to mike leech For This Useful Post: | ||
LOL ^^^^^
I have some cool coating on my intake valves and anticipate quite the power increase. |
The only coatings I've saw work are carbon skirt coatings. They wear fit to the bore to deal with bore distortion without scuffing. The work well and keep engine noise down. Other than that?
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. Last edited by mike leech; 08-20-2016 at 10:48 PM. |
Yup, that's pretty. Looks like chrome.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
Eagle has a similar finishing process they claim increases power. It looks promising but I have not tested the process. Anyone have any non supplier data?
My girlfriend uses some sort of coating on her hair. One of the 12 or so bottles of stuff in the shower. Can't say it helps with HP or wear, but it does smell good
^^^^^this TTTMF's
One way to tell if the various coatings and products make a measurable HP difference is when specific sanctioning bodies and rules committees ban or outlaw the coating product or process. If no one pays any attention, in my experience, the HP gains are anecdotal or negligible.
