Intake gaskets for kre d-port 310cfm?
Anyone know what size intake gaskets are used on kre 310cfm d-port?
KRE claims a gasket opening of 1.20 x 2.3 is used on the 310 cfm head.
Gasket Dimensions
Here you go. Just happened to have a set close by. Hope this helps. Basically 1.16" x 2.40"
-Kevin
1972 Firebird 462, 6X heads, RA4 cam, iron intake, Cliff's Q-Jet 3925 race weight Best of 12.88 @ 105 so far |
Wow bigger than i thought for the 310cfm. Thanks
The SCE 128103 gasket would be a better fit. Despite what their catalog states that gasket has a 2.320" tall port opening x 1.170" wide.
It will be a bit difficult to find, I recently bought the last set at Summit and JEGS is out of stock. Check with Dave Bisschop , he sells it under a different number. .
Paul Spotts lists a Intake gasket that is 1.175" X 2.300".
We stock the SCE 128103 ..... We also have a much better quality gasket that's anti-freeze resistant.
325 Not 310
My bad. Gaskets I posted are for 325 cfm not 310. I just double-checked their website and 310 uses a 1.20 x 2.30 not the 1.20 x 2 40 I showed. Sorry for any confusion. Should have finished my coffee before posting.
-Kevin
Thanks guys, i looked at kre website and didn't see what they list for gasket for the head. Guess i missed it.
Info on Tin Indian Site
I found the info on the Tin Indian site in the parts section for gaskets.
http://tinindianperformance.com/Tin%...%20Catalog.htm
Tin Indian gaskets are a rip off of the SCE gaskets. Order from Paul !
The Following User Says Thank You to Steve C. For This Useful Post: | ||
