Old 09-10-2017, 07:47 PM
form74's Avatar
form74 form74 is offline
Default New Season New Best ET and MPH Finally
Best ET last year was 12.41 @ 108.59 and 12.45 @ 108.93 in about 50 degree weather mid November.
Link to last years post
http://forums.maxperformanceinc.com/...d.php?t=795187
Changes since last year
New 275 ET/SS tires, New drag 90/10 shocks and 1 inch lowering springs. Refreshed QJET from Cliff.
This year one 12.46 @ 108.95 right off the trailer early July, the best after that 12.58 @ 107.10 in Norwalk
Yesterday after taking 2nd in the street class where I had my best 60 ft ever at 1.686
Link to that :
http://forums.maxperformanceinc.com/...d.php?t=806531
I took a few more passes .
Took the Air Cleaner off , bogged terrible then recovered and ran a 12.361 @ 110.33
Put the Air cleaner back on and ran a 12.369 @ 109.91 followed by a 12.397 @ 109.32
Changes made since Norwalk were Exhaust upgrade from 2 1/2 to 3 inch from the manifolds to the tail pipes and swapped out the front tires 255/60's for some 205/75's
Can't wait for the Fall Cool air to see what it will run.
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.075 @ 112.70
12.092 @ 112.43
12.128 @ 111.71
Old 09-10-2017, 07:49 PM
off-idle launch?
What rpm do you upshift?
Old 09-10-2017, 08:05 PM
cnc's Avatar
cnc cnc is offline
Way to go Gary ..hopin to race your Ass one day ...think it would be a good one.....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 09-10-2017, 08:14 PM
Dave M's Avatar
Dave M Dave M is offline
Great job Gary!! Very impressed!
Old 09-10-2017, 08:16 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Good job Gary!
Go fast, see Elvis!
Old 09-10-2017, 08:49 PM
slowbird's Avatar
slowbird slowbird is offline
It's running good! I think it was your second to last pass i saw where it stumbled just after launch.
FWIW when we ran Q-JETs we found they liked having an air cleaner base on, if we ran with nothing it stumbled and just did run quite right. At least that was our experience.
Kevspontiacs@aol.com's Avatar
Kevspontiacs@aol.com Kevspontiacs@aol.com is offline
Congrats Gary
Old 09-10-2017, 09:07 PM
Torquewar's Avatar
Torquewar Torquewar is offline
Excellent , good to see the changes make a difference.
Old 09-10-2017, 09:40 PM
bad69bird's Avatar
bad69bird bad69bird is offline
Congrats man! Should definitely pick up even more with the fall air!
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs)
Old 09-11-2017, 12:58 AM
Dragncar Dragncar is offline
The PMD engineers were some of the best in Detroit in designing air cleaners that "worked". They were known for have nice induction, intakes manifolds, ex manifolds ect. The iron Q Jet intake is based on a early 60s SD unit.
Old 09-11-2017, 02:15 PM
form74's Avatar
Originally Posted by Half-Inch Stud View Post
off-idle launch?
Foot Brake @ 2,000 RPM
1st to 2nd approx 4,500 , 2nd to drive shift-light was set at 5,700 and i shifted right after that.
Yes it would
It had been a few years since I tried , won't do it again.
Was shocked when I got the Time slip and it was my fastest ET . MPH ever
So it recovered nicely.
74 Formula
3:42 gears
12.075 @ 112.70
12.092 @ 112.43
12.128 @ 111.71
Old 09-11-2017, 10:06 PM
goatmanmitch's Avatar
goatmanmitch goatmanmitch is offline
Nice job, Gary!
Mitch Kunath
Old 09-12-2017, 08:44 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Good job congrats! Nice to see the changes pay off
Chris D
Old 05-18-2018, 08:11 AM
form74's Avatar
Finally got out to the track last night for the first time in 2018. it was 53 degrees at the track.
Only upgrade was to replace the RobbMc 550 pump with a 1100 Pump and added a regulator.
First pass off the trailer was a 12.368 @109.78 - basically the same as last fall.
2nd pass was 12.258 @ 110.33
3rd pass 12.337 @ 109.74 - shredded the alternator belt
The rest of the passes were :
12.368 @ 110.19
12.364 @ 110.33
12.342 @ 109.99
12.313 @ 110.06
So two new Bests last night
A few time slips attached and what my Drag Radials looked like when I got to the Track. Just picked up some weld wheels to lighten up the car , just need to get some tires for them for the next trip to the track .
ID:	483257   Click image for larger version
74 Formula
3:42 gears
12.075 @ 112.70
12.092 @ 112.43
12.128 @ 111.71
Old 05-18-2018, 09:24 AM
PAUL K's Avatar
Keep up the good work Gary!
Go fast, see Elvis!
Old 05-18-2018, 11:05 AM
slowbird's Avatar
Cool, that PKMM engine just keeps getting quicker!
Old 05-18-2018, 08:12 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Great job. Enough mph for 11.99
Old 05-18-2018, 09:12 PM
Congrats on the new times!
I'd say you have a lot left in the car, ET wise.
Probably with some good slicks would be a lot quicker.
What is the stall on the converter?
Old 05-18-2018, 09:32 PM
congrats on the new bests.
Have you tried off-idle launch as better than holding at 2000 rpm?
Old 05-18-2018, 11:33 PM
Congrats Gary
