Old 01-23-2022, 08:44 PM
65sport 65sport is offline
Default Adjusting cam timing
I've already degreed the cam and need to advance the cam 2 degrees. My lower timing gear only has 4 degree options adv/ret.
The only way I can see is to use a SBC offset crankshaft key on the cam.
So if I use a SBC 4 degree offset crankshaft key on the Pontiac cam, will this give me the 2 degrees at the cam I'm looking for ?
Old 01-23-2022, 09:08 PM
tom s tom s is offline
I think a mopar key is avail.Tom
Old 01-23-2022, 09:13 PM
In the old days the mopar keys were used a lot.
If you find a source I would like to purchase at least 3 sets of the parts.
Old 01-23-2022, 11:12 PM
tooski tooski is offline
https://butlerperformance.com/search.html?q=cam+keys
Perhaps a bit pricey?
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 01-23-2022, 11:31 PM
Unobtainium, so far on google.
Old 01-23-2022, 11:33 PM
Those are Chevy crank keys.
Old 01-23-2022, 11:35 PM
Ah, the old days.... Gone.
Old 01-23-2022, 11:40 PM
Default Cam timking
Does anyone know how much the cam would move if I put a Chevy offset crank key on the Pontiac cam? If it's a 2 degree crank key, how much would that move the cam ?
Old 01-24-2022, 04:43 AM
Kenth's Avatar
Kenth Kenth is offline
Crank turns two revolutions while the cam turns one rev, so 2° on crank is 1° on cam.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-28-2022, 12:31 PM
TransAm 474's Avatar
TransAm 474 TransAm 474 is offline
Did you already try degreeing it using the +4 advance slot to see what the result was? I've seen some 9 keyway chain sets that only change the camshaft position +2 degrees when using the +4 slot, others advance more than 4 degree when using the +4 slot, just depends on the combination of everything, like the crankshaft keyway, camshaft keyway, the accuracy of the 9 keyway timing set cam/crank keyways. It has to be rechecked everytime that it is advance or retarded to verify that it moved the amount desired.
1978 Trans Am
Pump Gas 461 Stroker
The Following User Says Thank You to TransAm 474 For This Useful Post:
Old 01-28-2022, 03:24 PM
This^^
https://youtu.be/XqEydRRRwqE
Old 01-29-2022, 10:49 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
^^^^^ x2
The cheby key would move the cam 1* which you probably would not even really find on the wheel. I know when I was dialing mine in....i call it +/- 1/2* = YAY!!!
Old 01-29-2022, 11:42 AM
It will double the number on the degree wheel. 2 degree offset key would show 4 degrees advance/retard depending on how the key is installed
Sold new at Ace Wilson's Royal Pontiac
http://www.youtube.com/watch?v=cUHC-Z8xhtg
Old 01-29-2022, 02:17 PM
Quoting Jim Hand on 6/15/2000:
"As the cam rotates at half speed from the crank, one degree change at the cam equals two degrees at the crank. Accordingly, a one degree change in location of the cam will shift the lobe center two degrees at the crank. So a two degree cam key will change the cam timing by four degrees!" End quote.
The discontinued Mopar offset keys contained a set of 5 color coded keys. The natural metal key is 1 degree, which would give you the 2 degree advance that you're looking for. I'm not aware of anyone else making a 1 degree key
Old 01-29-2022, 03:03 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
Last time i needed a 1 degree cam key (2 at the crank) i welded and reground a 2 degree cam key. No issues Works fine and didnt take long. Jon
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 01-29-2022, 03:14 PM
mgarblik mgarblik is offline
The Mopar 5-pack color coded keys were really great, but I haven't seen any for sale in at least 10 years now. They were sold as a "Direct Connection" performance part. So that goes way back. If you want to go the offset key route, probably the best thing to do is Google "Mercedes offset woodruff key". That will bring up multiple sources for Mercedes offset keys from 1 to 5 degrees that will fit our Pontiacs. Each key is about $10.00. Hope this helps.
Old 02-14-2022, 02:08 AM
This^^
I see what you are getting at, I need to put the degree wheel on and experiment. Sounds like it's hit or miss sometimes using the multi crank gear positions but I may be able to correct it with a cam key going whatever direction I need it to. Sure wish they made the Mopar keys again.
The Following User Says Thank You to 65sport For This Useful Post:
Thanks I'll try that.
Old 02-15-2022, 06:37 PM
Yes, most definitely hit and miss, it must be rechecked after every change to verify how much it actually moved.
1978 Trans Am
Old 02-15-2022, 08:05 PM
61-63's Avatar
61-63 61-63 is offline
Look in the Summit catalog they sell a timing chain setup that has +- 2,4,6,8 degree keeways on the crank sprocket.
