Old 04-18-2024, 10:51 AM
Tom Pugh Tom Pugh is offline
Default Down pipes from HO exhaust manifolds
I am installing a 455 in my '76 GTO. It will be using the Parts Place 2.25" exit HO manifolds ( Ames sells a 2.5" version but they were on backorder. I want to run 2.5" downpipes all the way back to the mufflers. Will there be a problem mating the 2.5" downpipes to the 2,25 HO manifolds or will I need to stay with 2.25 pipes all the way back?
Old 04-18-2024, 01:42 PM
form74's Avatar
form74 form74 is offline
I have 2 1/2 inch manifolds mated to 3 inch exhaust.
A short section of 2 1/2 inch pipe was stretched to 3 inches on one end and welded onto the three inch pipes using the 2 1/2 inch flanges
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.075 @ 112.70
12.092 @ 112.43
12.128 @ 111.71
Old 04-18-2024, 02:42 PM
MatthewKlein MatthewKlein is offline
I used 2.5 downpipes on 2.25 manifolds
It was necessary to grind the exhaust pipe to clear the manifold studs
Old 04-18-2024, 04:12 PM
Cammer-6 Cammer-6 is offline
post pics of said 76 GTO
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 04-19-2024, 09:15 PM
400 4spd.'s Avatar
I have a pair of 2.25 flanges if you need some, 2 stud and 3 stud.
Old 04-23-2024, 07:52 PM
I have the flanges, thanks
