Old 02-15-2009, 07:05 AM
ponchbro's Avatar
ponchbro ponchbro is offline
Post Procomp HEI Distributors?????
Have any of you run Procomp HEI or there electronics??? There prices are good!!!
Thanks for your feedback!
Old 02-15-2009, 07:49 PM
Sun Tuned Sun Tuned is offline
Price may be good, but you better pull it completely apart and clean out every crevice of the thing and put grease in the grease well before ya try and light it off first.
Old 02-15-2009, 09:15 PM
Don't lemme scare ya off from buying one they are o.k. they are just like anything else that comes out of a box.... they need a little tlc. Clean it up and get all that aluminum machining chips they didn't take the time to clean out, out of it and lube it up , adress the advance curve to your specs and run it. When the electronics finally take a dump as they do eventually, upgrade it with premium quality stuff as it needs replacing, till then run it like it is and you'll be fine. No since spending money just because unless you need to.
