Interesting on the ferrite beads. I looked them up and they are very short clip on things. Do you have to buy a bunch of them to cover the entire length of your USB cables, or just one clip on ferrite bead does the whole cable??? |
I covered a lot of the USB cable you cannot see. Left the cable uncovered that's visible running down the mount to my old Ipod Touch. Without the modifications outlined, the operation of my Ipod was a real s**t show. FWIW, also read that too much ignition advance can make things worse with the HEI interference, no idea about that.
65 Tempest, 400, TH400 86 Fiero SE 2.8 |
The Following User Says Thank You to MarkS57 For This Useful Post: | ||
I don't have RFI issues at the moment but have been watching for solutions just in case. |
The Following User Says Thank You to Formulajones For This Useful Post: | ||
Hi I like your diagram but have 1 question. the 2 wires that go to the original coil, 1 is the resistance wire and other is positive from the started so I can tape off or remove the hot wire and just put the resistance wire on terminal 86 and just use the fused wire from the battery in place of the wire I remove from the starter correct?
The Following User Says Thank You to thebrat1967 For This Useful Post: | ||
On later engines Pontiac used a circuit off the solenoid to supply power to the coil when ignition switch was turned to the start position, You have two choices - leave the wire from solenoid to coil in place and only add the resistance wire to the relay, or you can take both resistance wire and the wire from solenoid together to energize the relay.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon in progress. |
The Following User Says Thank You to lust4speed For This Useful Post: | ||
You MUST check for voltage when there is current flow. No resistor will drop the voltage until current flows. When current flows, you'll find about eight volts. You will not get full power potential from the ignition coil when it runs off of eight volts instead of thirteen-plus. The HEI is designed to draw a huge amount of power through the ignition coil, intentionally limited by circuitry in the ignition module. When starved for voltage, the module increases the dwell time to compensate. But that "uses up" all the available dwell-time, leaving no additional for higher-RPM operation. Quote:
AVERAGE amperage draw of an HEI is very reasonable. PEAK amperage is quite high. In other words, the HEI needs pulses of power, and the wire gauge has to be sized to allow the peaks, not just the average. |
The Following 2 Users Say Thank You to Schurkey For This Useful Post: | ||
Did not read all the replies.
Has anyone mentioned that the HEI will, most likely, require hammering the sh!t out of the firewall in order to physically fit in a '67? And even then, the wire boots may still be rubbing. In my old '67, I swapped out the HEI installed by a previous owner for a Small Body from Dave (www.davessmallbodyheis.com) . I wasn't convinced that the HEI wasn't getting tweaked when the moved under WOT.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
The Following 2 Users Say Thank You to Lee For This Useful Post: | ||
I was able to install an HEI on our 67 FB, but there is no room for error. Ours has a stock 326 with stock motor mounts. The only way for ours is to point the vac cannister towards the pass side.. There should be just enough rotation to dial in your timing.
I had read that they would need to have the firewall hammered in to fit, or they just wouldn't fit at all, but I must he blessed. The HEI is great. Reliable and kicks a great spark. Only downside is originality. I run 12v relayed power to mine also. Last edited by Hotrodjohn71; 04-15-2023 at 11:33 AM. |
You can start by feeding terminal 86 with the resistance feed and the bypass feed. You could possibly terminate the bypass feed to it and try that too. I can’t remember if all vehicles keep the resistance feed alive while the ignition is in the start position or if they sometimes just tie bypass to “start” and then engage resistance wire in the “run” position. There’s a note about it in the bottom left of the diagram. |
The Following User Says Thank You to Entropy11 For This Useful Post: | ||
