Sometimes you have to just gather your information over time and let the lay on the side of the road (conversation). I have owned 22 RA-IV camshafts in my life and a couple of the HO Racing similar designs. Several cams, I sent to Camshaft Machine Company and had them compared to their Master Camshaft info by Don Hubbard and Glenn Corwin. Don was VP of CMC and Glenn was Chief Engineer. But the point is everyone has their opinion. Some have facts, some have a lot of facts because they MADE the stuff. Tom V. Where you install the camshaft (advanced, retarded, etc), can have a effect on how the camshaft sounds at the rear of the car.
I have never found a need for Rhoads on the RAIV style camshafts when placed in a 455. As long as the cam is installed at a proper ICL and you have a decent distributor curve with enough initial timing, a standard lifter on that camshaft will idle really well and produce 12+ inches of vacuum easily. Setup the same way with Rhoads lifters I can make that camshaft idle baby smooth in a 455 as if it doesn't have a big camshaft at all, great for a sleeper build if you want a smooth idle, but not really necessary for vacuum production in a street car. Compression will play a roll in this, and the more you have the easier it is, but if setup properly it works well enough even in a low compression 455. As an example I did a hydraulic roller 239/243 @ .050 cam in a 10:1 455 on a 112 LSA, with standard roller lifters. By most peoples standard on the forum you would be led to believe that would be way too radical for a street car. I'll tell you it's very tame and easily daily drivable. Even up here at 5000 feet elevation where engines typically make 3-4 inches less vacuum, that engine still idled at 850 rpm making 12 inches of vacuum, and once installed in the car worked the power brakes and AC just fine. It just has a mild lope at idle. Down at sea level you'll see the vacuum increase to 15+ inches. Here it is on the run stand with a vacuum reading https://youtu.be/FIYRsDTD_90 Here it is in the car https://youtu.be/AOqwz3QlO5k |
Based on the one page I have from a catalog that is shown as the TC-03 / 041HL
Stan
Some say a flat tappet solid lifter camshaft will idle like a smaller camshaft vs a hydraulic camshaft. Maybe it is so. All I know is I ran a solid lifter 255/260 .540/.565 106 c/l cam on the street for many years and did not have drive-ability issues.
But the car did not have Power Vacuum Brakes. If I reinstalled that camshaft in another engine I would use the Hydraboost system to help with the brakes. All Mustangs from 1996 had that system as PRODUCTION on those applications. (as have many GM/Ford trucks). More than one way to resolve vacuum issues with brakes and larger camshafts. Tom V.
Stan
Stan Weiss/World Wide Enterprises Offering Performance Software Since 1987 http://www.magneticlynx.com/carfor/carfor.htm David Vizard & Stan Weiss' IOP / Flow / Induction Optimization - Cam Selection Software http://www.magneticlynx.com/DV Download FREE 14 Trial IOP / Flow Software http://www.magneticlynx.com/DV/Flow_..._Day_Trial.php Pontiac Pump Gas List http://www.magneticlynx.com/carfor/pont_gas.htm Using PMD Block and Heads List http://www.magneticlynx.com/carfor/pont_pmd.htm Last edited by Stan Weiss; 12-19-2021 at 11:23 AM. |
So Tom, are you saying I am wrong?
That is a proven fact that if both cams have the same 0.050" duration. Now that said how much different will depend on a number of factors. One of the major factors is the height of the lash ramp. Stan
Alright. I ordered some hylift johnson lifters. We'll see how it goes. Thanks everyone
1970 Formula 400 4 speed 2006 Gto. Ls2/m6 1972 Gto 455ho/th400 post coupe 1973 Grand Am 400 4 speed |
The Following User Says Thank You to big matt For This Useful Post: | ||
Thanks Stan.
Happy Holidays to you and Family. Tom V.
Tom,
A Happy Holidays to you and your Family, and also everyone here on PY. Not to take this thread off topic I have started a separate thread about cam 0.050" duration. Stan
The TC-03/041HL is a torque converter combo. we recommended the TC-03 with the 041HL The TC-03 was(is) a 10" converter based on the "SuperTorque" line of converters. CROCIE JR. still uses this line of converters . Low slip at cruse and appropriate stall for the cam involved, P/N 16020 from Art Carr-Cal. Performance Transmission.
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
Ken,
I have seen a few cam cards post over the years where there is a letter following the cam number. Like TC-01 TC-01A TC-01C and the number look different. Could explain this? Thanks, Stan
Stan and others
The HC-01A, B, C. etc. were designations for the cams we had made from different grinders. They were all similar dur, & lift. Even back then, grinders ran out of cores .Unfortunately, the designations vs manufacturer vs specs are lost in history. After all, this was happening 30 years ago!
The Following User Says Thank You to KEN CROCIE For This Useful Post: | ||
At the minimum, Ken, you probably would have had a Camshaft Machine Cam, A Universal Cams camshaft, a TRW Camshaft, possibly a Clay Smith Camshaft, with a lot of the cores supplied by CWC.
Just going from memory. Tom V.
