Old 03-04-2024, 05:34 PM
gman005's Avatar
gman005 gman005 is offline
Default Oil question
What are you guys using in your race engines?
Brad Penn or VR1?
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
Old 03-04-2024, 07:08 PM
chuckies76ta's Avatar
Oh Boy. I run 20W50 Amsoil in our race engine. And the reason for the heavy oil is bearing and rod clearances. Solid roller.
The Following User Says Thank You to chuckies76ta For This Useful Post:
Old 03-04-2024, 07:31 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
I've been running the VR-1 20/50 for years. Like Chuckie, my clearances are on the looser side.
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
Old 03-04-2024, 08:06 PM
gman005's Avatar
I have been using Brad Penn 20w-50 for years. My engine builder wants me to use VR1. So has Brad Penn changed the formula? I know VR1 is less money but I just want to know what everyone is using.
71 Lemans Sport.
72 Lemans Sport.
Old 03-04-2024, 08:25 PM
Scott Stoneburg's Avatar
I run Penn 10-40
Old 03-04-2024, 08:44 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
I’ve run the vr1 20/50 but lately Mobil one 10/40 might go to vr1 10/30 at some
Point
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 03-04-2024, 11:15 PM
blueghoast's Avatar
20-50 VR1 for me I heard brad penn took out the good stuff like zinc ddp
and all the break in additives that used to be in it.
Check to be sure for your own results.
GT
Old 03-05-2024, 01:45 AM
Dragncar Dragncar is offline
Shaffers, been saying it for awhile. The Best.
This guy did back to back dyno test on a 400ish LS engine on a chassis dyno.
Pretty significant numbers for just oil.
https://www.youtube.com/watch?v=Zm-AmTkxD_A&t=1119s
Name:	Screenshot 2024-03-04 at 21-42-35 SCOTUS Rules On Trump Ballot Case As Complex Outside Threats C.jpg
Old 03-05-2024, 08:32 AM
Don 79 TA Don 79 TA is offline
I like Motuls ester oil
i run 20-60, which can now only find 10-60
i live in high temps
oddly the 20-60 sounds so thin too
Old 03-05-2024, 09:00 AM
bluegoat65 bluegoat65 is offline
10w/30 Lucas race only. I run Bullet .384 lobe, solid flat tappet with 1.8 Ford rockers. 2 on the rods and 2.5 on the mains.
Old 03-05-2024, 10:03 AM
Elarson's Avatar
Elarson Elarson is offline
Grocery Getter and my new road race engine both use VR-1, 10w-30.
Eric
The Following User Says Thank You to Elarson For This Useful Post:
Old 03-05-2024, 10:36 AM
JLBIII JLBIII is offline
My engine builder recommended Brad Penn 10-40.
Old 03-05-2024, 11:21 AM
Jay S's Avatar
Jay S Jay S is offline
Not that I have seen???
The oil analysis’s come back the pretty much the same.
Old 03-05-2024, 02:44 PM
Old Goat Racer's Avatar
VR1 10W30.. But I'm not as fast as some of you guys.
Everybody knows somthin.
Nobody knows everything !
Old 03-05-2024, 06:05 PM
sdbob sdbob is offline
I dont know. I've been running 10-40 Pennzoil in my street SD and the stocker SD I race, Forever.
Old 03-05-2024, 09:31 PM
I need to edit. I'm using 10-30. I was using 10-40 Royal Purple. But when I had my motor on the Dyno, the operator was uncomfortable with how high the oil pressure was with the RP 10-40. We switched to Penn 10-30 and it lowered the oil pressure by quite a bit at high rpm. Idle pressure held the same. I will try to find the info to put real numbers to it
Found it ...dropped about 38psi @ 5000-6000 rpms
Old 03-05-2024, 11:58 PM
beemergary's Avatar
Picking up my new shortblock from machine shop tomorrow. He suggested BradPenn. I'll ask the weight.
Old 03-06-2024, 11:00 AM
Dragracertoo Dragracertoo is offline
VR1 Synthetic 10-30/20-50 depending on bearing clearance
Old 03-06-2024, 11:22 AM
65madgoat's Avatar
Driven 15W-40 for me
Old 03-06-2024, 12:12 PM
Mr Anonymous's Avatar
VR-1 20w/50 on engines with throw-at-cat-thru-it bearing clearances, and their 10w-30 on stuff thats likely to survive.
Clutch Guys Matter
53 Studebaker, 400P/th400/9"
64 F-85
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
