Freaking snowballing projects
Well pulled the 81 car out , charged the battery fresh gas so my daughter could drive it while in for Turkey Day,it was her high school car.Had a vibrtation liek falt spotted tires or maybe the 20 year old shocks were gone so ordered new schocks. Got it inspected but on the way home someone pulled out in front and I had to hit the brakes hard. Took a hard left turn locking up one rear wheel. So figuire the ratchet caliper was stuck might be lucky enough to just adjust it, or just a collapsed brake line.-Nope needed a new caliper-luckily I bought lifetime warranty a Hi Lo in the late 80s! My 5th new caliper for both cars. So miked the rotor since I was there-too thin so new rotors. So front brake probably need replacing too.
Pulled off the caliper yesterday and saw previous owner spliced a compression fitting in the line-luckily have an extra line laying around. So this car was a daily driver and rear looks grungy-so do I pull it ans clean and paint it since lines and calipers will be off, than why not freshen the bearings right! And while the rear is out scrub and paint the rear undercarriage right? And maybe go ahead and get new spring as the rubber shcakle bushings are starting to crack. It never ends!
Hey Skip, you left out Cryoing it all!
I'll let you stay at my place and feed you for free if you want to trade the crap that needs to be fixed on the Pontiac!
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
Paul if it gets a 455 inplace of the old stock ish 400(which still runs like a top) it will use some of those valve springs you cryo'd for me! Why I might freshen the 96K mile rear end if it gets a little more hit with more TQ.
Oh forgot to mention lining up all the spoilers better than the body shop did when it was repainted after getting a door skin 7 years ago-not even my daughter's fault-she was at her grandparents and the neighbors backed into it. I guess I'm too anal about things being just right!
Skip while your at it fly to Delaware and help me with my 79 T/A.
Conrad 79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers. |
68 Firebird, trying a q-jet now. 434/10.5:1/997's/240-242 HFT/4L80E/2800 Yank/3.42's/ Vintage Air/ 13.0 @105 mph 70 Lemans, 350/350, A/C, mostly stock 14 Ram CC, 5.7 Hemi, 8-speed, 3.92 lsd 97 Trans Am, HPP Aug 2012 http://www.highperformancepontiac.co...tiac_trans_am/ ***Sold*** |
I thought project snow-balling like that was normal? Isn't it!?!
Deal is all of these things required attention, just now your priorities changed, and you decided to address the issues as you found them on the car.
Keep up the good work, Skip. Tom Vaught
Yea then we pull the rear apart and the posi needs new clutches-now discontinued-so need a new posi, then rear gears set up. And I haven't even gotten to the front brakes yet!
I really wanted this to be a quick deal to get back on the Camaro/IA since I just got the cage put in it! Just money and time right
Put some gas (or berryman's) in it (again), while working on the 81,to make sure the tank's good to go...
Skip congratulations on being an hourly shop father. Flat rate dad would have charged the old battery, put in a paper floor mat and sent it on its way.
"Get the camaro gas tank back yet???"
No this side tracked the Camaro tank.
