Old 08-14-2021, 09:46 PM
Valley Pan Valley Pan is offline
Default Fuel Injected Intakes
Has anyone seen the prices of these intake manifolds?
https://www.speedmaster79.com/Pontia...Manifold-Satin
https://www.speedmaster79.com/Pontia...ifold-Polished
Old 08-14-2021, 10:05 PM
Schurkey Schurkey is online now
"Speedmaster".
Pretty much says it all: Chinese junk from a company infamous for Chinese junk. No fookin' way, not at any price.
Old 08-15-2021, 03:08 AM
NeighborsComplaint's Avatar
Huh. I wish some one would have told me that. I thought that since my ProComp intake fit perfectly, was finished very nicely requiring only a gasket match and my 455 ran better than with the prior HSD, it was a nice intake. Just shows how little I know.
Triple Black 1971 GTO
Old 08-15-2021, 04:37 AM
Dragncar Dragncar is offline
Well, he good news is that are one piece of solid aluminum that can not blow your engine to bits from poor manufacturing.
Seriously though, they are decent intakes. My 9-1 455 runs 11 flat with one. Mine was worked on a bit by SD Dave. really nice intake for ported iron heads IMO.
Old 08-15-2021, 10:18 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
A Tomahawk with the bosses already drilled.
Skip Fix
The Following 2 Users Say Thank You to Skip Fix For This Useful Post:
Old 08-15-2021, 11:23 AM
Nobuddy Nobuddy is offline
A bit strange that the version machined for injectors is priced so much lower.
Maybe overstock or is being discontinued.
Old 08-15-2021, 11:26 AM
And for the haters, these are the old "Procomp" brand, which I hear is even more hated than "Speed master".
Old 08-15-2021, 11:34 AM
HWYSTR455's Avatar
Don't forget you need their' rails too...
Old 08-15-2021, 11:38 AM
HWYSTR455's Avatar
Oh, by the way, these intakes are not made in china, they are made in Australia.
The Following 2 Users Say Thank You to HWYSTR455 For This Useful Post:
Old 08-15-2021, 09:02 PM
The one I have says "Made in China" in the casting.
Old 08-16-2021, 07:09 AM
HWYSTR455's Avatar
Maybe at one time they were, but PCE foundries are in Australia.
Old 08-16-2021, 08:41 AM
Steve C. Steve C. is offline
This posted on another site....
Speed Master ,"a global company", is headquartered in Australia with some R&D and production facilities there but production of a lot of their products is outsourced to other countries.
Old information here:
The Following User Says Thank You to Steve C. For This Useful Post:
Old 08-16-2021, 08:55 AM
HWYSTR455's Avatar
Interesting, thank you steve c. for that information, noted!
Old 08-16-2021, 09:04 AM
Tom Vaught's Avatar
Boost Engineer
Almost all of the cast aluminum intakes out there (aside from the Holley and Edelbrock stuff) has been produced for many years in "Other Countries" China being the big one.
Ford of Australia did have casting capabilities for many years in Australia, prior to getting out of that production market.
Edelbrock was far bigger in the aluminum casting business than many would realize and produced castings for over 70 years in the USA.
Tom V.
Old 08-16-2021, 09:23 AM
grivera's Avatar
grivera grivera is online now
Speedmaster rails?
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 08-16-2021, 09:25 AM
HWYSTR455's Avatar
Originally Posted by grivera View Post
Speedmaster rails?
Yeah, the brackets too, they make a rail/hardware kit, but looks like some are not in stock at the moment.
Injector spacing is specific to the engine families. You can have them made, but that can become cost prohibitive.
Old 08-16-2021, 09:35 AM
Skip Fix's Avatar
Wonder if the Edelbrock rails would work?
Skip Fix
Old 08-16-2021, 09:43 AM
HWYSTR455's Avatar
Maybe if you make your own stands, but it can be a challenge. The injector spacing is correct though.
Old 08-16-2021, 02:54 PM
Tom Vaught's Avatar
Boost Engineer
Since the question about Fuel Rail mounting hardware was raised in a post, here are the dimensions for the "RAIL RETENTION BRACKETS: (SHORT & TALL)
These dimensions are taken from Victor and Super Victor Intake mounting hardware.
Tall Mounting Bracket (STEEL) STRAP: .090" MATERIAL THICKNESS
TALL BRACKET HEIGHT (STANDING ON END ON A FLAT SURFACE: 2.780"
OUTSIDE WIDTH OF THE "U-MOUNTING BRACKET (BOLT END): .750"
OUTSIDE WIDTH OF THE "U-MOUNTING BRACKET (RAIL END): .870"
MOUNTING BOLT HOLE: .290" DIAMETER
MOUNTING BOLT HOLE (FUEL RAIL BOLT): .280" DIAMETER
SHORT Mounting Bracket (STEEL) STRAP: .090" MATERIAL THICKNESS
SHORT BRACKET HEIGHT (STANDING ON END ON A FLAT SURFACE: 1.600"
OUTSIDE WIDTH OF THE "U-MOUNTING BRACKET (BOLT END): .930"
OUTSIDE WIDTH OF THE "U-MOUNTING BRACKET (RAIL END): .930"
MOUNTING BOLT HOLE: .280" DIAMETER
Have fun trying to make these things. It is not going to be a easy process
as you need 4 brackets, for a manifold, minimum.
Tom V.
Old 08-16-2021, 03:41 PM
HWYSTR455's Avatar
Edelbrock has 2 different brackets and maybe rails too, depending on the type of injectors you use.
The rails for the SpeedMaster are here:
https://www.speedmaster79.com/Pontia...ector-Rail-Kit
There's two different ones, not sure which kit is for which intake, would have to check. But the brackets for the one appears to be simple 'L' type. Might be able to fab something for the Edelbrock ones. You would need to mock it up, the pad on the intake is the determining factor I believe.
