im running a dick miller rear susp..no-hop bars,adj.uppers,12 way qa1 shocks & a anti-rollbar. up front 90-10's & moroso spring's i would like to get the car scaled and set up by a local chassis guy but try'ing to explain that this is a big long wheelbase car & that it is heavy(3600lbs).im running a 29.5x10.5 et drag.curious what kind of pinion angle should i be setting it at. with 6"pinion i'v cut a best of 1.35 60" but normaly cut's 1.41-44's 60" 6.05-6.25 in the 1/8.mile the motor makes 600hp & est 200hp on the nos.the motor can handle more nitrous but i cant hook what i got need some advice any + or-.
DiD you try lowering Your tire PSI?
That helps Sometimes. I bet you already did though.
72 Lemans |
Believe 72 lemans, you'll be surprised how much 1# will make a difference.
On my big pontiac 1# has made up .10 in the 60' on a poorer track. I'll run 15.5# at my home track but 16-17# at Norwalk. to get the same 60'. I read a post here on pinion angle but I'm disgusted with trying to search this site for anything. 2-4 degrees I think.
NHRA tech. "Its just a 412, I swear it". Pontiac tip of the year, quit those damn cigarettes. |
re: to make it hook........
hang back on the right side and rotate the arms thru the shot....... seriously, getting up in the hp levels, slicks don't last as long also. don't know how many passes u are trying to get out of a set? at 800hp maybe 35 passes with good traction, then iffy after? be another thread but, curious to know of others, how many passes u are trying to get from a set of 10.5s at 800hp or so?
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
yep..im thinking its my slicks too i got maybe 25-35 passes but the car sat for 5 months they look new but thiers probly no more sticky compound in them. im just curious to what pinion angle guy's are running with this much power and similar hp.hooks fine on motor very consistant1.54's 60' foots.i need to keep a woreout set for motor passes and get a new set for the money races
I have mine set at 5 degrees. So far best 60' was 1.39. That is with a 10.5 tire and stock upper and lower arms. I did relocate the mounting point (on the rear)on the lower arms.
Mike S |
I have the same Dick Miller suspension, including the anti-roll bar and I run two degrees of pinion angle. The car hooks good and makes about 700 HP. My best 60' is 1.38 with the average around 1.42. The car weighs 3140 with me in it and I have MT ET Drags, 10.5 X 28 X 15 stiff sidewall. The biggest variable in 60-foot time is the density altitude. I average 40-50 passes per pair of slicks.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
That's a big car, try a smaller lighter car. Your are pushing the evelope for that much power for a big battle ship. For pinnion angle each car is different. It depends how much rotation your rear has under load. For a four link the range is usually around 3-5 degrees negative.
Tim C
Tim Corcoran |
if ur slicks are getting greasy and on the edge, try swapping wheels around to the other side of car.
i see guy's swaping wheels from one side to the other.always wondered why thanks JC YOU ill try it but gonna try and get some new tires before the next FSTA race this weekend
6 degrees is too much pinion angle for your car, it would be close on a leaf spring car where the springs wind up and the rear end rotates up in the chassis. in a factory style 4-link application, i would say -2 to -4 degrees. in a "race car" style 4 link -1 degree, and in a ladder bar car -2.5 the closer to 0 the harder it hits the rear tires. do check your tire pressure, tire condition, shock settings, look in the rear suspension for any bind also. that tire is capable of plenty of power. is it a W series?? the tires will start to fade approx. 20-30 passes.
call me if you need any more info. 262-968-2514 www.xtremefabrication.com thanks, kal |
you can use VP tire conditioner or traction compound to squeeze some life from your older tires.
kal |
Did you guys see the videos that Jon Burchmore did of his firebird's rear suspension and slick on several launches? That video told the story about how his tire couldn't handle the hit on launch. Very cool research he did with that little camera.
Knock Knock Knockin' on 11's Door '70 Judge, Palladium Silver w/Red Interior Powered by SD Performance, Ported 6X Heads 501 HP, 554 ft lbs TQ 12.14 ET @ 114 MPH , Supercase Muncie M22, 3:55 Suspension: HO Racing, BMR< Sykorat, and Bilsteins Narrowed 12 bolt , 16x8 VintageWheel Works, Comp T/As on street, MT Drag Radials @ Strip http://www.sdperformance.com/custome...1.php?carID=42 |
