Old 10-16-2021, 04:07 PM
Glasshalffull Glasshalffull is offline
Default What 4 barrel manifold will fit a 326 block
Would like to put a four barrel on a 1967 tempest 326 Pontiac what original Pontiac manifold will allow me to do that. thank you
Old 10-16-2021, 04:25 PM
Stuart's Avatar
Stuart Stuart is offline
I think any Pontiac intake from 1965 through 1971 should bolt on.
The Following User Says Thank You to Stuart For This Useful Post:
Old 10-16-2021, 07:28 PM
sdbob sdbob is offline
Pontiac had a 4 bbl intake for carter afb carbs(basically a square bore intake all bores same size)and one for a Rochester quadrajet (rear bores are large).
Old 10-16-2021, 07:43 PM
All 1965 and 1966 and some 1967 Pontiac V8's used AFB manifolds and all will fit your 326. In 1967 some used Quadajet carbs and all 1968 through 1971 Pontiac V8's used them. Those manifolds also will fit your 326. Try to get manifold and carb because there are differences between the carbs and it is always easier to use the correct carb.
Old 10-16-2021, 10:50 PM
Default Thanks
Thanks to all!
