#521
I think he's talking about ceramic coating for the paint.
#522
gotcha
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
#523
Ask the Painter how to look after it. Mine is 12 years old and still looks good. I don't wash it, but use detail spray and microfibre towel to clean it. Lots of good wax. But mine is not a daily drivers as it sounds like you want for yours. Not quite sure on the ceramic coating thing yet, could be just a gimmick.
64 Lemans hardtop 4spd, buckets |
#524
It takes months for a paint job to finish outgassing, and would think you would want to wait until it has before applying anything on it. (other than pure carnauba wax).
The 'nano' coats are good, but are expensive. And they are usually not easy to apply CORRECTLY. Even if applied correctly, they are only good for a few years. Cleaner/polishes remove it too. Personally, I would say use only quality waxes and polishes, as well as soaps, and there's no reason to use the 'nano' products. I'm a meguiar's fan. .
The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
#525
The Following User Says Thank You to 1968GTO421 For This Useful Post: | ||
#526
The 'inexpensive' 'nano' or 'ceramic' coats done by detailers are rarely applied correctly, it's more a 'fad' than anything. Now a good job does stay for a while, but they are in the 800-1200 range, which is not cost effective.
On a brand new car, that you want to be low-maintenance, it's not a bad idea. You can use 'hybrid' or combo stuff, like wash & nano, or other hybrid waxes. That's fine, but on a 'real' paint job, an above-standard paint job, you really don't want to do that crap. You need to let it breathe, wax with a pure wax or +wax with natural oils (depending on paint type), twice a year doing a cleaner/polish wax, maybe clay bar every 2-3 years. If you look at collector grade cars, no one uses 'coatings'. No free lunch. UV and fall-out are the 2 big killers of paint jobs. If you drive it, wash it, maybe detail-wipe before you garage it, and follow a care schedule. It's really no-brainer. .
#527
Jeff |
#528
Thank you
#529
The Following User Says Thank You to 64speed For This Useful Post: | ||
#530
Car is in final assembly. I pick it up Nov 19th. Could have been sooner but he’s 7 hours away and scheduling conflicts prevent it.
#531
X2 on the pics/ slow video
#533
Here’s all the pics he sent today.
#534
Dressing her out
#535
And a little more
#536
Here’s a little more
#537
Looks great! You just can't beat fresh paint
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
#538
Lookin' good!
#539
Did you have the "post" trim reanodized or is it just polished? It looks great, as does the whole car.
#540
Everything is chromed. Every piece of shiny metal
