Old 10-16-2021, 07:51 AM
1lemans 1lemans is offline
Default glasstek hood 68 gto
anyone got pictures of the hood springs they supply fitted on the hinges?The ones i got seem short.They are already stretched heaps before you even close the hood.This is on a 68 gto.Thanks Peter
Old 10-16-2021, 02:35 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Sorry I don't have pics but I just ordered a hood from them. Did you get std or the 2" raised hood? Did you go hood pins or latch? I'm interested in pics, especially around the scoops. I got the raised hood and plan to use pins without a latch
Chris D
Old 10-16-2021, 08:46 PM
i got the 2" raised hood bolt on type. When it said "bolt on"i assumed it would have the hole wear it locks to the latch reinforced with a metal piece. I am going to cut that piece out of an old lemans hood i have and glass it in so i can use the latch. I'll take some pics of the scoop area and try to post them. Never put pics up before so bear with me it might take a while. I'm not real good at this computer stuff lol. Peter
The Following User Says Thank You to 1lemans For This Useful Post:
Old 10-17-2021, 05:29 PM
GTO JONES's Avatar
GTO JONES GTO JONES is online now
On mine I sent Glasstek the metal latch part from an old rusty hood and they molded it in the hood that way I can latch it normal and no hood pins. I got the springs from them to, thought I was going to loose a nut putting them on but it went OK.
Old 10-18-2021, 04:35 AM
sorry OCMDGTO i cant work out how to post the pics. if you pm me your email i'll send them to you. Cheers Peter
Old 10-18-2021, 08:13 AM
OCMDGTO's Avatar
GTO JONES were you able to use the stock cowl trim by the windshield?
Chris D
Old 10-18-2021, 10:47 AM
XLR8STEVE's Avatar
XLR8STEVE XLR8STEVE is offline
Yes, the springs seemed short on my bolt on also. they work great though. i got the regular bolt on. i will be looking for a 2" raised and sell this one during the winter. see pic.
Name:	hood springs.jpg
[SIGPIC]
Steve
Old 10-18-2021, 11:21 AM
GTO JONES's Avatar
If your talking about the chrome strip on the back edge yes.
The Following User Says Thank You to GTO JONES For This Useful Post:
Old 10-26-2021, 12:12 PM
OCMDGTO's Avatar
Here's pics the OP sent me in case anybody else wants to see them
ID:	576152   Click image for larger version
ID:	576153   Click image for larger version
ID:	576154   Click image for larger version
Chris D
Old 10-26-2021, 12:23 PM
GTO JONES's Avatar
Yeah, I cut the openings out on mine and put the chrome strip on the back edge. My son and I did other mods to like adding the L88 air box to it making it full time RA. (his idea) works great.
Old 10-26-2021, 01:29 PM
OCMDGTO's Avatar
GTO JONES what did you guys do with the grill by the windshield? Pics?
Chris D
Old 10-26-2021, 01:36 PM
GTO JONES's Avatar
We left it like alone, I thought about cutting it . I have a lot of pics for some reason I have difficulty getting them on here.
Old 10-31-2021, 06:05 PM
NeighborsComplaint's Avatar
I bought their springs for my '71 hood. They would not keep the hood open and were too light for my hood. I ordered a pair of heavier springs from NPD and they work fine. NPD has a light spring for small A body glass hoods (Chevelle) and a heavier spring for the long 442 and GTO hoods. Not sure where '68 falls but I suspect it is shorter and lighter than the '71.
Triple Black 1971 GTO
Old 11-03-2021, 06:43 PM
Here's my Glasstek hood on my '71. The body shop cut the openings, filled the reveals on the fake scoop inserts and installed the mesh grilles I made up that match the bumper. The hood was none too smooth as delivered either.
The Following 2 Users Say Thank You to NeighborsComplaint For This Useful Post:
Old 11-03-2021, 07:21 PM
tempest1964's Avatar
NC, that looks great. I especially like the mesh material. It looks like it would be stock. Very nice!
Old 11-03-2021, 11:51 PM
Thanks! Used 442 hood locks … my original hood popped open at about 75 mph. I didn’t want to repeat that thrill ride and was concerned about no louvers at the back of the Glasstek hood for air to exit from underhood.
Old 11-05-2021, 09:39 AM
To the OP, you hood scoops are much better than what the did on my ‘71. Your reveal line is deeper and will look fine when painted and your louvers can be drilled and at the ends and opened with a router or Dremel. On mine they didn’t even cast in the louvers and the reveal around my scoops was too shallow. My painter tried to leave them and they filled in with paint and looks a mistake. I made him strip the hood, fill the reveals and repaint. Within a year, I got bulges in the hood surface at all the hood crossmember locations and had to strip and paint it again. Tried to get Glasstek to cover it and the told me to pound sand as all fiberglass hoods shrink over time.
