Ram Air II Refresh
I'm starting to plan out my winter engine refresh project around a set of Ram Air II heads and wondering how to optimize around them.
Current setup: Original '68 400 .040, #16 heads non-ported 1.65 stamped rockers Lunati Voodoo 702 -14cc dished Icon pistons Stock iron intake w/ '68 Q-Jet Ram Air Manifolds 2.5" Pypes exhaust TH400 w/ 13" Continental Stall 3.55 Posi A/C, PDB With the RAII heads, I'll be using round port RARE manifolds, a Ram Air IV intake w/cross over (heads are ported on the intake side), and keeping the Q-Jet, but that's about all I have planned so far. The easiest thing would be to swap heads and call it a day, but since I'll have the engine out to do a reseal I'm wondering if I should consider a cam swap as well. Plans could change depending on the condition of the bottom end. The engine was built about 10 years ago and has low milage, so it should be ok. Would love to hear thoughts on how to build a stout streetable setup around these heads. Also, given the rarity of these heads, is there anything I should avoid in terms of machining that might diminish the value? I assume hardened seats, new guides and seals are safe starting points.
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
The Following User Says Thank You to Verdoro 68 For This Useful Post: | ||
Sounds like you have a sound shortblock personally I would get one of the Butler hydraulic roller ram air cams have the heads setup for the cam. I don’t know the cc of the heads but depending on what they check you will be able to keep compression under 10.1 with your dished pistons and different head gaskets available.If you don’t want the expense of a hydraulic roller a bigger hydraulic will work also. The other thing might be the converter what’s the stall? I do know a r/a IV cam with a stock 13” converter is like having a rev limiter on the engine till it hits 2600 rpm then it comes alive. One other thing to think about is the 3.55 gears of coarse a r/a II or IV could only be had with a 3.90. or 4.33 gear. So if you would go with a r/a IV spec cam cruising at under 2600 rpm the car will sound like it has a slight miss of course it doesn’t your just not into the cam rpm range yet. Back in the 80-90’s I had 3.55 gears in my GTO and had a r/a IV in it my buddy’s would say “can’t believe this car runs so good with that miss” I would just smile.
In terms of a Cam pick and then maybe the need/ use of the 1.65 rockers on the exh lobe’s I would get the heads flow tested and hopefully in 050” increments and with the intake bolted on if possible,and then average out those numbers to see if the motor will really need the exh lobe’s to have more duration and more lift than the intake side does.
In stock form those RAII heads have a high then needed exh to intake ratio.
I was looking through the Butler catalog - one of their Ram Air series rollers in the existing short block could be a good option to build off what I have.
Interesting thought with the 1.65 on the exhaust side. Related - the heads have the original tulipped valves in them. Is there any reason to keep them or am I better off replacing them with some new stainless Ferreas? Seems risky to keep 50+ year old valves. I’m kind of gambling on the intake. I bought a repro RA IV anticipating that it will need a lot of work. If it needs too much, I have an iron ‘68 I can port match. The stall in it now goes to about 2000 when you’re easy on it, higher when you flash it. I don’t want to go any higher on the rear gear, but a different stall is on the table. I always regretted not getting the 10” Jim Hand special instead of the more conservative 13”.
Something comparable to the 10” JHS would be great for a r/a profile cam. Stock 13” converters are very tight your 13” might not be. You could always change that later if you don’t like it. If you go hydraulic roller I personally would replace all the valves with something better like you said 50+ years old. They wouldn’t be a good choice for a roller setup if new.
Tulip valves are a disaster on the intake side of those D port heads, but on the exh side they will pick up exh velocity at low lift and help out with those heads too large exh throat size.
The main throat of the exh is 1.65”, the intake bowl throat is only 1.60”. If anything it should be the other way around! At any rate do not run 50 year old factory valves unless you like to gamble!
RA II heads are round port I think?
Given the rarity of these heads, I wasn't sure if there was any hit to the value if I did a standard rebuild with of new guides, hardened seats, new valves and clearancing for 1.65 if necessary. However, it would all be a wash if I used old parts and I dropped a valve and destroyed everything. Better safe than sorry I suppose. Besides, they're already ported on the intake side so it's not like they're totally virgin.
This is going to be a long term project. Got in touch with my builder the other day and he has a 9 month backlog but said he could squeeze me in. I'll start stockpiling parts in the meantime.
Good aftermarket valves won’t hurt the value of the heads.
And keep a head from popping off and grenading rare heads!
I have never heard any racer anywhere complaining on too much flow in the exhaust. The bigger the better.
Also, i have found the main reason Pontiac made the exhaust ports round and boltholes further apart was for the racers to attach the tube headers easier with larger seal surface to prevent gasket leaks. |
until a hardened seat fall out, than all bets are off.
“We don’t build a ‘luxury’ car. We build a performance car then we make it luxurious.” |
Kenth, then all I can say is that you’ve only been talking to uninformed racers with poor knowledge of why overall intake and exh ratios in conjunction with the motors cam spec’ s and compression are so important to max out a given combo’s power.
The Following User Says Thank You to steve25 For This Useful Post: | ||
Good luck getting those round port RA exhaust manifolds if you are thinking Ram Air Specialties. But at least you'll have better luck finding some for a '68 and up chassis.
Ames had them in stock, which surprised me. Not sure who makes them, but I figured if Ames stocks them, they’re good quality. I know the d-ports have been very hard to find.
This is why I wouldn't have hardened seats installed.
'69 GTO Convertible - Acquired October 2020. An all original project car. Restomod is underway PROJECT THREAD '83 Chevy Choo Choo SS El Camino - LT1 350/4L60e, Owned for 30 Years, completed 2nd restomod in 2018 PHOTO 2019 BMW 440ix - Twin turbo I6, 8spd auto. PHOTO '55 Chevy Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed Sept. 2012, Sold Sept. 2021 PHOTO |
Joe Sherman about I/E flow ratio. Quote:
There's no such thing as silent flow when doing a Exh flow test, especially once flow numbers of around 160 cfm are attained, its loud!
But that said, turbulent gurgling sounds and pop's are a sign of trouble and non smooth flow if you want to look at it that way. Exh flow should sound non turbulent thru out the whole lift range, not just from around .400" and up, I I take real issue with Darin on that statement! On the other side of this whole debate we have Smokey. From his extensive testing long before many of these other people where around ( or even had Dyno's of there own to beat a motor up in 24/7)in terms of his 600 hp SBC paved oval motors he stated that 250 cfm on the Intake side and 200 cfm on the Exh side where the numbers he found to work with these combo's and there 12.5 to 1 compression ratios. That's a 75% ratio. While we are looking at info, let's look at all of it!
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 10-11-2021 at 06:16 AM. |
In 2006 Darin stated the only Pontiac heads he did were the 455SD heads on Don Kennedy's Super Stocker in 1989. Reportedly set the NHRA record. Years later he did Kauffman high-port heads and intake for Mike Semchee that won Engine Masters contest. https://www.motortrend.com/how-to/ho...ontiac-engine/ Darin did some work for Jim Robertson here. Quote:
Harold Brookshire Ultradyne cams and did work for Lunati, Comp would change cam splits depending on E/I ratio. John Angeles on his RAIV SS car he has run for decades has a single pattern cam also.
