Old 04-24-2005, 08:34 AM
shaggy69gradprix's Avatar
shaggy69gradprix shaggy69gradprix is offline
im running a dick miller rear susp..no-hop bars,adj.uppers,12 way qa1 shocks & a anti-rollbar. up front 90-10's & moroso spring's i would like to get the car scaled and set up by a local chassis guy but try'ing to explain that this is a big long wheelbase car & that it is heavy(3600lbs).im running a 29.5x10.5 et drag.curious what kind of pinion angle should i be setting it at. with 6"pinion i'v cut a best of 1.35 60" but normaly cut's 1.41-44's 60" 6.05-6.25 in the 1/8.mile the motor makes 600hp & est 200hp on the nos.the motor can handle more nitrous but i cant hook what i got need some advice any + or-.
Old 04-24-2005, 12:08 PM
Bad Karma's Avatar
Bad Karma Bad Karma is offline
DiD you try lowering Your tire PSI?
That helps Sometimes. I bet you already did though.
72 Lemans
Old 04-24-2005, 04:20 PM
tikiklubracing's Avatar
tikiklubracing tikiklubracing is offline
Believe 72 lemans, you'll be surprised how much 1# will make a difference.
On my big pontiac 1# has made up .10 in the 60' on a poorer track.
I'll run 15.5# at my home track but 16-17# at Norwalk. to get the same 60'.
I read a post here on pinion angle but I'm disgusted with trying to search this site for anything.
2-4 degrees I think.
NHRA tech.
"Its just a 412, I swear it".
Pontiac tip of the year, quit those damn cigarettes.
Old 04-24-2005, 04:45 PM
J.C.you's Avatar
J.C.you J.C.you is offline
re: to make it hook........
hang back on the right side and rotate the arms thru the shot.......
seriously, getting up in the hp levels, slicks don't last as long also. don't know how many passes u are trying to get out of a set? at 800hp maybe 35 passes with good traction, then iffy after?
be another thread but, curious to know of others, how many passes u are trying to get from a set of 10.5s at 800hp or so?
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 04-24-2005, 05:17 PM
yep..im thinking its my slicks too i got maybe 25-35 passes but the car sat for 5 months they look new but thiers probly no more sticky compound in them. im just curious to what pinion angle guy's are running with this much power and similar hp.hooks fine on motor very consistant1.54's 60' foots.i need to keep a woreout set for motor passes and get a new set for the money races
Old 04-24-2005, 05:38 PM
Mike S's Avatar
Mike S Mike S is offline
I have mine set at 5 degrees. So far best 60' was 1.39. That is with a 10.5 tire and stock upper and lower arms. I did relocate the mounting point (on the rear)on the lower arms.
Mike S
Old 04-24-2005, 08:48 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
I have the same Dick Miller suspension, including the anti-roll bar and I run two degrees of pinion angle. The car hooks good and makes about 700 HP. My best 60' is 1.38 with the average around 1.42. The car weighs 3140 with me in it and I have MT ET Drags, 10.5 X 28 X 15 stiff sidewall. The biggest variable in 60-foot time is the density altitude. I average 40-50 passes per pair of slicks.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 04-25-2005, 07:29 AM
Tim Corcoran's Avatar
That's a big car, try a smaller lighter car. Your are pushing the evelope for that much power for a big battle ship. For pinnion angle each car is different. It depends how much rotation your rear has under load. For a four link the range is usually around 3-5 degrees negative.
Tim C
Tim Corcoran
Old 04-25-2005, 09:03 AM
J.C.you's Avatar
if ur slicks are getting greasy and on the edge, try swapping wheels around to the other side of car.
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
Old 04-25-2005, 03:26 PM
i see guy's swaping wheels from one side to the other.always wondered why thanks JC YOU ill try it but gonna try and get some new tires before the next FSTA race this weekend
Old 04-25-2005, 03:41 PM
warriors revenge warriors revenge is offline
Send a message via Yahoo to warriors revenge
6 degrees is too much pinion angle for your car, it would be close on a leaf spring car where the springs wind up and the rear end rotates up in the chassis. in a factory style 4-link application, i would say -2 to -4 degrees. in a "race car" style 4 link -1 degree, and in a ladder bar car -2.5 the closer to 0 the harder it hits the rear tires. do check your tire pressure, tire condition, shock settings, look in the rear suspension for any bind also. that tire is capable of plenty of power. is it a W series?? the tires will start to fade approx. 20-30 passes.
call me if you need any more info.
262-968-2514
www.xtremefabrication.com
thanks,
kal
Old 04-25-2005, 03:44 PM
you can use VP tire conditioner or traction compound to squeeze some life from your older tires.
kal
Old 04-25-2005, 05:11 PM
Silver Judge's Avatar
Did you guys see the videos that Jon Burchmore did of his firebird's rear suspension and slick on several launches? That video told the story about how his tire couldn't handle the hit on launch. Very cool research he did with that little camera.
501 HP, 554 ft lbs TQ
