Old 12-23-2014, 07:07 PM
Alvin's Avatar
Alvin Alvin is offline
Arrow Any 1970, 71, 72 Trans Ams built with Hood Tachometers?
Throwing this question out there to others who have more knowledge and experience than I do on 1970, 71, 72 Trans Ams. Were the UPC "U85 Tachometer, Hood Mounted" aka: Hood Tachs ever available as an option on Trans Ams?
Originally Posted by rexs73gto View Post
Alvin you have the page out of the 73 order book but in the 70-72 order books the hood tach was an option for the birds & you could have it on a T/A also but the tach was a delete if you ordered the hood tach & got the large clock in that left pod. Otherwise you would end up with 2 tachs & that would be stupid looking to have a tach inside & one on the hood to.
1970, 71, 72 Trans Am with UPC "U85 Tachometer, Hood Mounted" not found
Don't see it on this 1972 Firebird order form http://www.gt-37.org/gallery/main.php?g2_itemId=5184
====> Or this Special Equipment 1972 order form http://www.gt-37.org/gallery/main.php?g2_itemId=5226
Don't see it on this 1971 Firebird order form http://www.gt-37.org/gallery/main.php?g2_itemId=7035
====> Or this Special Equipment 1971 order form http://www.gt-37.org/gallery/main.php?g2_itemId=7041
UPC "U85 Tachometer, Hood Mounted" IS shown on this 1970 LeMans Sport & GTO order form http://www.gt-37.org/gallery/main.php?g2_itemId=7014
Perhaps you can find it as you described above and share it with us from one of these order forms? http://www.gt-37.org/gallery/main.php?g2_itemId=1675
Old 12-23-2014, 07:09 PM
Alvin's Avatar
Wink
Never say never - right? Post them if you have any documented 2nd Gen 1970, 71, 72 TRANS AM built with a hood tach please!
Old 12-23-2014, 07:14 PM
Alvin's Avatar
Never say never - right? Post them if you have any documented TRANS AM built with a hood tach please!
Reason for the 2nd Gen Hood Tach question post# 35 here http://forums.maxperformanceinc.com/...14#post5326514 Thxs.
Old 12-23-2014, 07:56 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Never seen one or heard of one ever being built.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1993 Trans Am
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
2006 GTO
Old 12-23-2014, 08:32 PM
Alvin's Avatar
Wink
Thxs. "Well someone on the Internet said...'Bonjour!'"
Old 12-24-2014, 04:52 AM
AkCamaro AkCamaro is offline
I think that one ^^^ was built late in the day on a Friday.
Old 12-24-2014, 06:46 AM
Alvin, I don't know where my old book is but I remember that in my little sales book the one that use to go in my pocket, it's about 4 inchs wide by 10 inchs tall. But in there I think is where I remember seeing it last. But in my order book when you got into the gauges there was an astrist & when you went down to the bottom of the book you saw the note saying that when useing the hood tach that the in dash tach was replaced with the large clock & there would be an additional charge of ?? At least thats where I think I saw it last. I'm not 100% sure but I do remember the astrist then the note to go with. It was similar to when you got a hood tach on the A-bodies there to was a note about the speedo with the trip odometer. But thats a different subject. As I mentioned before the only hood tachs I've ever seen on an F-body has been a Formula, & now that T/A in the pic post.
Old 12-24-2014, 02:14 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
I'm going to say no to the factory installed hood tach.
No mention of it in the factory assembly manual.
The hoods lower brace structure has no cut outs or features to provide clearance for the fasteners and wiring.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 12-24-2014, 02:56 PM
MikeNoun's Avatar
MikeNoun MikeNoun is offline
I have the 1970 order forms, 1970 price sheets, and 1970 Pocket Facts.
Hood tach was not available on the 1970 Firebirds, or the 1969 Trans Am's.
The Following User Says Thank You to MikeNoun For This Useful Post:
Old 12-24-2014, 05:17 PM
Alvin's Avatar
Cool
Thxs for the input. Seeking any verifiable Trans Am factory hood tach info like the attached "1970 Tempest Hood Tach Installation" page courtesy www.gt-37.org for 1970, 71, 72, 73 Trans Am.
Old 12-25-2014, 01:18 AM
robertf's Avatar
robertf robertf is offline
Old 12-25-2014, 04:29 AM
I have to disagree with you when you say that no firebids came with a hood tach. As I had mentioned earlier in this post I have seen 3 formula's with hood tachs on them. The one that is here in town is owned by the original owner & he has the build sheet for his with the hood tach listed on it. Wheather there is a place in the bracing for it to come through the hood for mounting or not the hood tack was availabe on the formulas , if not the Trans Am's .
Old 12-25-2014, 09:29 AM
Judge273's Avatar
Judge273 Judge273 is offline
if so pix? Documentation too would be so cool.
I know a couple of 72 455 HO verts that the original owners swear were GTOs because they ordered them that way, only to find out the dealer did the magic...
Mike/Illinois
Old 12-25-2014, 11:28 AM
Alvin's Avatar
OP title: Any 1970, 71, 72 Trans Ams built with Hood Tachometers?
Bonjour & Merry Christmas!
Old 12-25-2014, 09:50 PM
Rex, yes - pls post that build sheet. If it shows a hood mounted tachometer on it the history books will need a small re-write.
Old 12-27-2014, 04:21 PM
transam1972 transam1972 is offline
Default 1970 FORMULA
from the cover of HOT ROD...most likely an early GM car...I think a hood tach looks good on a Formula hood..a T/A not so much..perfect for a Formula with out the gauge option...I am not buying 2 tachs on a car..overkill
ID:	385598   Click image for larger version
The Following User Says Thank You to transam1972 For This Useful Post:
Old 01-12-2015, 11:16 PM
Bentwheelbob's Avatar
While flipping through some 1972 Firebird literature I had in an attempt to help answer Brewster's question on what came with the Custom Trim option, I found this little gem on hood tachometers. Far from conclusive as others have pointed out that the sales literature was not gospel, but interesting nonetheless.
Old 01-13-2015, 12:20 AM
giles's Avatar
giles giles is offline
Originally Posted by Bentwheelbob View Post
While flipping through some 1972 Firebird literature ...I found this little gem on hood tachometers. Far from conclusive as others have pointed out that the sales literature was not gospel, but interesting nonetheless.
Hmmm, accessory catalogs are produced by the sales dept. The original intent was to add options to a plain Jane car, but they kind of expanded to try to sell anything to anyone if it would function.
Yes the yellow 70 pilot Formula was built with a hood tach, but thankfully the RPO was cancelled in regular production. I've seen no order forms, invoices, build sheets or window stickers indicating an early 70s Firebird came off the end of the line with a hood tach. Unlike a RAIV Formula I have seen no evidence that it was even theoretically available.
Old 01-13-2015, 10:52 AM
Alvin's Avatar
This ^^^^. Interesting to see the "(D)" for Dealer...slap some options on and of course the text referring to the instrument panel Tach-O-Meter standard on Trans Am...
Old 01-13-2015, 08:05 PM
Default FORMULA HOOD ON A TRANS AM
..forget the Formula hood and a shaker.(CHiPs) anyone?!).but when you look at that T/A and forget about the shaker & tach...if the TRANS AM had only come with the fiberglass Ram Air twin scoop hood and the stripes on top of the scoops to match the roof & deck lid like originally planned a shakerless T/A looks pretty darn cool..imagine if it had been the other way round (like the S.D. 455 FORMULA)..I think the TRANS AM would have looked sleeker and way cool (plus I would have that dual scooped hood!!)
