will wheel adaptor cause front tire to rub
I have a 70 GTO stock suspension.
I am looking at buying a set of Cragar 15" Mach 8 rims (they are hard to come by) The backspace on the rims is 4.5" they were on a 70's Dodge van The GTO is 4.75 so it appears an adaptor is the only way The adaptor will push the wheel out 1" the back has air shocks jacked up it is the front that is my concern I used a 1" adaptor on a catalina to convert Rally II to work the tires rubbed can a machine shop drill out the rims or is it to risky and expensive If some one knows of a thinner adapter please let me know |
Seems you can drill from 4.5 to 4.75?
the rims have what is called a vari lug i thought was to be the place to go from 4.5 to 4.75
seems vari lug will work with 4.75
there is a spacer that goes in the back of the wheel and oval lugs for the front anyone knows if this is correct please reply |
