3rd Gen F-Body Rear Disc.
I was wondering if a rear disc brake setup off an '86 Firebird will fit my '70 Lemans? Also, would I still be able to keep the 14" wheels, or would I need to upgrade to 15" wheels? If that is the case, I might as well, since the tires are in need of replacing.
if I remember right, the 4th gen rear setup is pretty close to the 1LE 3rd gen rear setup I know for sure the 4th gen rear disk will not clear 14s, you need at least 15s (I think the rotor is around 11.8 or so in diameter) Im pretty sure the the 3/4th gen rear axle flange pattern is the same essentially as the old 8.2 BOP axle flange
www.fquick.com/Captainofiron 68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4 97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil 14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires |
The Following User Says Thank You to Captainofiron For This Useful Post: | ||
You will need to figure out how to retain the axle with a custom plate or spacer since your diff is bolt in axles. The calipers are cast iron and the same design ratcheting e-brake setup on the 79-81 trans ams, but smaller. For me this setup is too finicky and would not confer enough benefit over drums for all the work. If you have a chevy rear diff it would be a bolt on and you'd need to figure out how to connect the e-brake cables. For the effort I would put 15" rallys on the car and get a set of disks from an S10/Trailblazer. It's a much better design, lighter and easier to work on with a drum in hat e-brake. You still need a spacer.. There is a member talking about this in the suspension forum right now. |
The Following User Says Thank You to Donovan For This Useful Post: | ||
Thanks.
I was wondering. So It would be best for me to look for the '88 and later for the 3rd Gen, as well as even one off a 4th Gen, right? What's good about a 4th Gen, I can ALWAYS go back to my '02 Firebird to reference it. Saw a '99 Firebird at that same U-Pull-It salvage yard. Thanks. This will help.
So 15's I would need to convert to, correct? Was planning on it, since my 14x7's are in need of new tires, as well as new studs for the axles and even converting to a posi-traction differential. |
If I remember right the LS rear disks will not fit under 15 inch wheels, but the LT disks will. The LT have a parking brake lever on the caliper, but the LS disks have the parking brake drum inside the rotor Here is an LS setup Here is the LT Check out this link http://www.carcraft.com/techarticles...kyard_builder/
I prefer the LS type with the parking brake inside the hub of the rotor. I have a 2nd gen WS6 set up on my 72 Formula and the corkscrew setup in the rear calipers is not a great design. It's a pita to get right and never really grabs tight enough on a steep hill. I don't like putting the weight of the car on the trans either so I'd be interested in knowing what's involved in using an LS era rear disc setup on 2nd gen as well as 68-72 A-body's.(?)
___________________________________ "Objects in mirror are closer than they appear" |
for what its worth the 4th gen rear axle flange is the same as my BOP 8.2
Ok. Will be looking out on these.
Thanks. This helps much. Unfortunately, I did NOT see the 88 to 97 F-Body rear disc brakes (aluminum ribbed caliper). Only saw the earlier ones and the later ones. Will keep looking for the meantime. Thanks much.
The Following User Says Thank You to SteveGB21 For This Useful Post: | ||
1979 TATA Extreme TKO .64 Hedman elite; Pypes 2.5; Borla XS; MSD 6A; Edelbrock intake; open scoop; Sniper Q-jet; Powermaster 150; 4 core radiator/Mark VIII fan; RobbMc mini starter; subframe connectors; solid body mounts; fiberglass rear springs; poly sway bar and link bushings; 81 master; D52’s; Blazer disks; 225/60 & 235/60 17's TrueContact's; relays for PW, PDL, lights; keyless entry |
Avoid this style all together. Use the trailblazer rear disks that fit in the same wheel.
That's what I suspected, thanks for the input. Yes, I am planning the Trailblazer set up for an install this summer. Not only a functional parking brake, but a little bigger disks as well, always a good thing.
But, I have seen the Trailblazer, Envoy, 02 Bravada, Rainer have a 6 lug bolt pattern. This would be the S10 chassis ones with 2WD, correct? Was also wondering about that conversion as well.
Yes, the parts can come from an S10 and 3 or 4 other models. I think the 2 wheel drives have the 5 x 4.75 lug pattern.
There is a very detailed write up here: S10-Blazer rear disc conversion
The Following User Says Thank You to MNBob For This Useful Post: | ||
the 4th gen LT type arent bad, its very mountainous here and I have parked on some serious inclines and havent had problems
If I remember right, the rear axle in the 4th gen is the same axle used on the S10 and Astro vans
The Astro/Safari vs. S10/Sonoma
Captain Of Iron,
I heard the early Astro/Safari vans have the 2WD Truck/B-Body 5 lug 5" bolt pattern. Then in 2001/2002, it changed to the 6 lug bolt pattern that the earlier 4WD models used (and then the 99 to present Silverado/Sierra trucks), up until 2005 when GM ceased production of their RWD/AWD minivans (more trucklike than carlike). The Blazer/Jimmy and S10/Sonoma that were 2WD did have the same 5 lug 4.75" bolt pattern. So you live up the freeway from me (I-10)? Cool. There are some hills and even the mountains (same in El Paso, depending where you're at). Did notice some junkyards with older cars in Las Cruces. I do need to check there. Also have seen Alamogordo has some as well. |
There is a thread on using 98-02 rear brakes on 2nd Gen TA’s here:
Rear Disc brake conversion One poster in the above says that he has done this rear conversion four times and it fits 15x8 snowflake and Turbo wheels. Both the LS and the S10 Blazer systems are great upgrades with the hat parking brake system. However, if you want to use mostly new parts, I found the LS system is considerable cheaper.
It could be that the Astro vans are 5x5, Im not sure
I have the ls rears and they will not fit my stock 15's but I have 17s so who cares. Supposedly the s10 do fit stock 15's if yo want to run 15s still.
My stock 10 bolt had a ton of axle play and would have had a ton of pad knock back had I not gotten a Detroit trutrack where I could "tune" the end play out of the axles. |
17's are nice, but I want to keep the TATA look with the Turbo wheels.
