Old 01-26-2022, 06:03 PM
gman005's Avatar
gman005 gman005 is online now
I need a new larger shifter boot. I had to open up the tunnel a little. Who makes them similar to the original one?
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
  #82
Old 01-26-2022, 06:10 PM
gman005's Avatar
Here is a picture.
71 Lemans Sport.
72 Lemans Sport.
  #83
Old 01-26-2022, 06:58 PM
tom s tom s is offline
Look at a Gen2 bird boot,used one on my gen 1 with a TKO.Tom
  #84
Old 01-26-2022, 07:52 PM
AG's Avatar
AG AG is offline
Originally Posted by gman005 View Post
Here is a picture.
Will that work with a console?
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
  #85
Old 01-26-2022, 07:53 PM
gman005's Avatar
Do you know the dimensions? I need something like 6.5x6.5
71 Lemans Sport.
72 Lemans Sport.
  #86
Old 01-26-2022, 07:54 PM
gman005's Avatar
It better. LOL. It looks ok with the console in place.
71 Lemans Sport.
72 Lemans Sport.
  #87
Old 01-26-2022, 08:05 PM
70GS455 70GS455 is offline
Its a shame American Powertrain has not yet figured out how to make a shifter with the offset tower (as opposed to the offset adapter piece pictured). It would save a lot of us from cutting our tunnels when the shift tower comes up thru the shifter hole
Sent from my SM-G991U using Tapatalk
  #88
Old 01-28-2022, 12:31 PM
soupman soupman is offline
For shifter boot look at the 70’s CJ jeep 4x4 transfer boots. They are 4” wide by 7” long. Or close to that. I used it as the tunnel boot to seal, has a internal metal ring that helps secure it.
  #89
Old 01-28-2022, 03:40 PM
VCho455's Avatar
VCho455 VCho455 is offline
I've talked with two people here locally who have been dissatisfied with the quality of the mechanical speedometer adapter that was supplied by their vendor. Both experienced oil leaks from the adapter. One gentleman was able to source a different adapter from a local speedometer repair shop that solved the leaking.
Has anyone else experienced this?
  #90
Old 01-28-2022, 04:09 PM
Formulajones's Avatar
On a TKO??
The only piece you need for a retro swap in a GM vehicle is a simple short cable that adapts a GM speedo cable to the Ford style speedo gear setup. It just has a simple gear attached to the end of the cable and it's housing is sealed with an o-ring to the trans itself. It seals like any other speedo gear setup in any stick or auto trans, just a simple o-ring.
I've never had any issue with them leaking.
Now I have had one instance where the Ford style speedo cable leaked some fluid that came through the crimped portion of the cable, but that was on a complete Ford cable on a Ford vehicle. That was an easy fix, I just used a short piece of adhesive heat shrink over the sleeve, problem solved.
But I've never had that issue with the short adapter used for GM swaps and I've done dozens of those.
https://youtu.be/XqEydRRRwqE
  #91
Old 01-28-2022, 08:26 PM
MDL has the proper side shifter location for offset shifter applications
https://youtu.be/cnX-MrmvybY
  #92
Old 01-29-2022, 06:45 PM
67GTONUT's Avatar
67GTONUT 67GTONUT is offline
Do you have a link or a pic of what this looks like...... I am looking to seal off the tunnel better after my TKX install....
Thank you
Troy
Rockaway NJ
67 GTO
400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI
HOTCHKIS/UMI/BILSTEIN
  #93
Old 01-31-2022, 08:23 AM
rontiac's Avatar
rontiac rontiac is offline
Ordered the American Powertrain TKX kit 1/14/22...........the last day of their holiday sale.
At that tiime, Ross said their was around a 2 1/2 week backlog due to the amount of orders coming in. Should be finalizing the package this week!
I can't decide whether or not to go with the white lightening shifter upgrade or not. I'll be using a manual console in the 65 LeMans.......... ( any input would be greatly appreciated! )
To the OP, Ross is very knowledgeable and more than willing to answer questions throughout the process. I'm quite impressed with the customer service at American Powertrain..............something that seems to have really dropped off these days.
http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=143670&dateline=12211  78868
1965 LeMans Post Coupe..............I'm not waitin for the undertaker....I'm lookin forward to the uppertaker!.....
  #94
Old 01-31-2022, 11:16 AM
I recommend the white lightening shifter. I've used it along with a couple other shifters and by far the white lightening is my favorite with much more adjustability and versatility. It shifts pretty darn nice too.
  #95
Old 01-31-2022, 11:26 AM
Unless you get a shifter with an offset shift tower, you'll be cutting metal
  #96
Old 01-31-2022, 07:55 PM
Here is an offset shift tower with which there is no metal cutting
  #97
Old 01-31-2022, 09:35 PM
VCho455's Avatar
On a TKO??
Both were onTKX's
  #98
Old 01-31-2022, 10:15 PM
Originally Posted by VCho455 View Post
Both were onTKX's
Yeah, the cable and speedo setup would be the same, nothing has changed in that regard between the TKO and the TKX.
  #99
Old 01-31-2022, 11:01 PM
AG's Avatar
AG AG is offline
Is that the shifter that Modern Driveline sells?
  #100
Old 01-31-2022, 11:08 PM
TB1's Avatar
TB1 TB1 is offline
its a package, trans and shifter like SST https://www.moderndriveline.com/prod.../64-67-a-body/
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt
