i need some help for swapping a turbo 400 into a friends 63 catalina with original motor. the starter bolts to the trans housing. did someone start making an adapter recently? anyone done this swap before? my cure was pull the 389 and install a late motor and trans.
In the "PONTIAC Racer"s & High Performance Handbook" by John Angeles/Pete McCarthy, there is a diagram of the adapter that you are looking for if someone isn't making one. It is on the page following 1965 ENGINE SPECS.
Bill
Bill 64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs. 8.2550@164.17-1/4, 5.2901@131.97-1/8, 1.1981-60-ft. 8/10/08 |
Check your block for the mounting tab for the block mount starter.
Usually I'm found working on my Pontiac. If you want to find me Look for the white picket fence and all the old Pontiacs parked outside. And the half dissembled engine sprawled all over the driveway!
Try calling CRUSHPROOF! 512-386-9889 |
gO TO WWW.WILCAP.COM AND CLICK ON NEW PARTS AND ALSO ADAPTERS. They sell a kit that has the adapter, flywheel, bolts, etc.
I am currently doing a TH400 into a '64 GP. Your block must be drilled and tapped to accept the newer type starter, if not then you must use an adapter. There are adapters available, call if you need help 408-629-4948. You must also use the flexplate for the TH400 and of course the yolk for the TH400. There is a minor modification to the rear crossmember but its no problem. You will also have to sort out the type shifter and the length of the drive shaft. It may seem like alot to do but its worth it as the Roto- trans is really junk even when its working as intended.
Thread Tools | |
Display Modes | |
